What if we were to press the RESET Button January 30, 2015 06:50AM |
Re: What if we were to press the RESET Button January 30, 2015 08:03AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: What if we were to press the RESET Button January 30, 2015 08:36AM |
Re: What if we were to press the RESET Button January 30, 2015 12:51PM |
Re: What if we were to press the RESET Button January 30, 2015 01:09PM |
Admin Registered: 16 years ago Posts: 13,895 |
Re: What if we were to press the RESET Button January 31, 2015 01:27PM |
Re: What if we were to press the RESET Button January 31, 2015 03:37PM |
Re: What if we were to press the RESET Button January 31, 2015 07:35PM |
Re: What if we were to press the RESET Button January 31, 2015 11:56PM |
Mutley3D
a one shot per layer printer im my view is impossible or cost prohibitive, unless your in the matrix
As someone above mentioned, there are other areas that can be improved/refined, but a full reset of implementation? I dont see it. Sorry to be negative but i think this is unrealistic.
Id equate the one shot per layer idea as similar to the difference between a car with wheels, and one that hovers 6 inches above the ground without any external assistance/equipment. In the movies, anything is possible but its not real life.
Id be happy to eat my hat if someone prove me wrong.
Re: What if we were to press the RESET Button February 01, 2015 03:50AM |
Re: What if we were to press the RESET Button February 01, 2015 04:59AM |
Re: What if we were to press the RESET Button February 01, 2015 05:10AM |
Re: What if we were to press the RESET Button February 01, 2015 05:18AM |
Re: What if we were to press the RESET Button February 01, 2015 06:53AM |
Re: What if we were to press the RESET Button February 01, 2015 08:59AM |
Re: What if we were to press the RESET Button February 01, 2015 09:17AM |
cat.farmer
Interesting idea. As laser toner is mostly plastic the mechanism to create the layer is already there. you would need to find a way to accurately lay the layers on top of each other and fuse them as they go.
There are a few high end devices that use Xerox's solid ink print head, they lay down (I think) 250 lines per head, not using plastic, more of a wax resin.
Re: What if we were to press the RESET Button February 01, 2015 09:51AM |
Re: What if we were to press the RESET Button February 01, 2015 10:12AM |
Ano
Wouldn't be a resin printer be better? Put an LCD-like device unter the tank and light up the form of one layer, then pull it up and the next layer follows. Could do the whole layer in one step
Re: What if we were to press the RESET Button February 01, 2015 11:07AM |
Re: What if we were to press the RESET Button February 01, 2015 12:07PM |
Re: What if we were to press the RESET Button February 01, 2015 12:47PM |
Re: What if we were to press the RESET Button February 01, 2015 01:00PM |
Ano
Something with power already exists. They use Lasers to melt the powder (or grain) on one spot. A laser is a great way, because switched off, it is instantely "cold". When you try to melt
plastic with a hot surface, you need to wait until it's cold to make the next layer. A pretty strong light source could be used...
Re: What if we were to press the RESET Button February 01, 2015 02:00PM |
Re: What if we were to press the RESET Button February 02, 2015 01:56AM |
Admin Registered: 13 years ago Posts: 7,007 |
Re: What if we were to press the RESET Button February 02, 2015 03:39AM |
Re: What if we were to press the RESET Button February 02, 2015 04:07AM |
Dust
This is why DLP printers where invented...
They print an entire layer in one go.
VDX
... google for SIS-printing (Selective-Inhibition-Sintering) - it's a combination of powderbed-printing with an inkjet (salt instead of binder) and an aerial IR-heater for melting the topmost surface in one pass
Re: What if we were to press the RESET Button February 05, 2015 01:23PM |
Re: What if we were to press the RESET Button February 05, 2015 01:58PM |
