Soldering resistor onto A4988's ROSC pin February 04, 2015 12:51PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Soldering resistor onto A4988's ROSC pin February 04, 2015 01:57PM |
Re: Soldering resistor onto A4988's ROSC pin February 04, 2015 02:02PM |
jtoombs
+1 for finding the answer. I would love to see how this is done. This could be very useful if it's effective and easy to implement.
Re: Soldering resistor onto A4988's ROSC pin February 04, 2015 02:11PM |
Re: Soldering resistor onto A4988's ROSC pin February 04, 2015 02:41PM |
MindRealm
Wooo! Found it
You short the R4 resistor on A4988 stepper drivers... The fix is described >>HERE<< (but in GERMAN)
Re: Soldering resistor onto A4988's ROSC pin February 04, 2015 04:03PM |
Re: Soldering resistor onto A4988's ROSC pin February 04, 2015 04:13PM |
dc42
Download the A4988 datasheet and work it out from that. I'd do that for you, but it's not very practical on a mobile.
Re: Soldering resistor onto A4988's ROSC pin February 04, 2015 04:26PM |
Re: Soldering resistor onto A4988's ROSC pin February 04, 2015 04:46PM |
I think it means the R4 is a 10K resistor and he is "bridging" it....meaning shorting it out.Quote
Ohmarinus
From translating it I found:
"so I have the R4 10k resistor bridges"
So this probably means I have to pull R4 to ground with a 10K resistor?
Re: Soldering resistor onto A4988's ROSC pin February 04, 2015 06:22PM |
On the Pololu A4988 boards a small resistance has to be bridged, here done with a small piece of wire:
[Attachment 37445 hack_pololu.jpg]
(Picture by hardware Killer)
Re: Soldering resistor onto A4988's ROSC pin February 04, 2015 07:15PM |
Re: Soldering resistor onto A4988's ROSC pin February 04, 2015 07:33PM |
Re: Soldering resistor onto A4988's ROSC pin February 05, 2015 01:44PM |
Re: Soldering resistor onto A4988's ROSC pin February 05, 2015 04:00PM |
Re: Soldering resistor onto A4988's ROSC pin February 05, 2015 06:01PM |
Ohmarinus
First experiments sound very promising, will upload a side-by-side comparison video later today Vibration is down by a lot and noise production by a bit
Oh, and it's superhard to solder an SMD that isn't stuck to the PCB! So I simply removed them and pulled a solder trace to short out R4.
Re: Soldering resistor onto A4988's ROSC pin February 05, 2015 08:00PM |
Re: Soldering resistor onto A4988's ROSC pin February 05, 2015 11:33PM |
Re: Soldering resistor onto A4988's ROSC pin February 06, 2015 07:51AM |
Re: Soldering resistor onto A4988's ROSC pin October 31, 2016 05:58AM |
Re: Soldering resistor onto A4988's ROSC pin October 31, 2016 07:49AM |
Re: Soldering resistor onto A4988's ROSC pin October 31, 2016 09:31AM |
Re: Soldering resistor onto A4988's ROSC pin October 31, 2016 11:43AM |
Re: Soldering resistor onto A4988's ROSC pin October 31, 2016 12:01PM |
Re: Soldering resistor onto A4988's ROSC pin April 22, 2019 09:32AM |
Re: Soldering resistor onto A4988's ROSC pin April 22, 2019 01:30PM |
Re: Soldering resistor onto A4988's ROSC pin April 22, 2019 06:04PM |
Re: Soldering resistor onto A4988's ROSC pin April 23, 2019 01:24AM |
Re: Soldering resistor onto A4988's ROSC pin April 24, 2019 04:31AM |
obelisk79
I'd love to see(hear) the before and after
Re: Soldering resistor onto A4988's ROSC pin April 24, 2019 04:47AM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: Soldering resistor onto A4988's ROSC pin April 24, 2019 04:48AM |
Dust
@Ohmarinus
ffmpeg can convert nearly all video and audio formats, and it free
Seems only slightly quieter... and that could be due to different recording devices...
