ABL is not even worth it anymore February 24, 2015 01:33AM |
Re: ABL is not even worth it anymore February 24, 2015 05:22AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: ABL is not even worth it anymore February 24, 2015 05:43AM |
Admin Registered: 13 years ago Posts: 7,007 |
Re: ABL is not even worth it anymore February 24, 2015 08:34AM |
Re: ABL is not even worth it anymore February 24, 2015 10:07AM |
Re: ABL is not even worth it anymore February 24, 2015 12:03PM |
Re: ABL is not even worth it anymore February 24, 2015 12:21PM |
rdzmzda
I use to have the extruder home to the front left of the board but the way I installed the servo it would never home as it was off the board.
Re: ABL is not even worth it anymore February 24, 2015 12:23PM |
Re: ABL is not even worth it anymore February 24, 2015 12:57PM |
Re: ABL is not even worth it anymore February 24, 2015 01:07PM |
danielis
No, the printer ist not printing in the center of bed after ABL. The printer starts with the print approximately 40mm to far on the left side.
Re: ABL is not even worth it anymore February 24, 2015 01:41PM |
Re: ABL is not even worth it anymore February 24, 2015 01:43PM |
Re: ABL is not even worth it anymore February 24, 2015 01:45PM |
Re: ABL is not even worth it anymore February 24, 2015 03:33PM |
X-axis limit switch location: Right or Left of the bed? _Right________________Quote
MindRealm
rdzmzda
We can work out the probe positioning separately from the home positioning. Let's first make sure your printer is set up to agree with slicer/print settings (0,0 is the same in software as your physical settings), then we can fix the ABL woes.
I need to know where the limit switches are located and how they're connected to your electronics:
X-axis limit switch location: Right or Left of the bed? _________________
Plugged into the board at X-MIN or X-MAX location? _________________
Y-axis limit switch location: Back or Front of the bed? _________________
Plugged into the board at Y-MIN or Y-MAX location? _________________
Z-axis limit switch location: Top or Bottom? _________________
Plugged into the board at Z-MIN or Z-MAX location? _________________
Re: ABL is not even worth it anymore February 24, 2015 04:30PM |
//=========================================================================== //============================= Auto Bed Leveling =========================== //=========================================================================== #define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (remove // at the start of the line) //#define Z_PROBE_REPEATABILITY_TEST //* MindRealm 022415: Commented out to assist in troubleshooting Auto-Level Routine #ifdef ENABLE_AUTO_BED_LEVELING // There are 2 different ways to pick the X and Y locations to probe: // - "grid" mode // Probe every point in a rectangular grid // You must specify the rectangle, and the density of sample points // This mode is preferred because there are more measurements. // It used to be called ACCURATE_BED_LEVELING but "grid" is more descriptive // - "3-point" mode // Probe 3 arbitrary points on the bed (that aren't colinear) // You must specify the X & Y coordinates of all 3 points #define AUTO_BED_LEVELING_GRID // with AUTO_BED_LEVELING_GRID, the bed is sampled in a // AUTO_BED_LEVELING_GRID_POINTSxAUTO_BED_LEVELING_GRID_POINTS grid // and least squares solution is calculated // Note: this feature occupies 10'206 byte #ifdef AUTO_BED_LEVELING_GRID // set the rectangle in which to probe #define LEFT_PROBE_BED_POSITION 30 #define RIGHT_PROBE_BED_POSITION 140 #define BACK_PROBE_BED_POSITION 140 #define FRONT_PROBE_BED_POSITION 30 // set the number of grid points per dimension // I wouldn't see a reason to go above 3 (=9 probing points on the bed) #define AUTO_BED_LEVELING_GRID_POINTS 2 #else // not AUTO_BED_LEVELING_GRID // with no grid, just probe 3 arbitrary points. A simple cross-product // is used to estimate the plane of the print bed #define ABL_PROBE_PT_1_X 170 //* MindRealm 022415: Changed these coordinates to avoid measurement on the same point in any axis. #define ABL_PROBE_PT_1_Y 170 //* #define ABL_PROBE_PT_2_X 110 //* #define ABL_PROBE_PT_2_Y 40 //* #define ABL_PROBE_PT_3_X 20 //* #define ABL_PROBE_PT_3_Y 140 //* #endif // AUTO_BED_LEVELING_GRID // these are the offsets to the probe relative to the extruder tip (Hotend - Probe) // X and Y offsets must be integers #define X_PROBE_OFFSET_FROM_EXTRUDER -38 #define Y_PROBE_OFFSET_FROM_EXTRUDER -30 #define Z_PROBE_OFFSET_FROM_EXTRUDER -2 #define Z_RAISE_BEFORE_HOMING 10 //* MindRealm 022415: Increased (old value 5) to be sure to clear all obstacles (binder clips, etc.) // Be sure you have this distance over your Z_MAX_POS in case #define XY_TRAVEL_SPEED 5000 // X and Y axis travel speed between probes, in mm/min #define Z_RAISE_BEFORE_PROBING 10 //How much the extruder will be raised before traveling to the first probing point. #define Z_RAISE_BETWEEN_PROBINGS 5 //* MindRealm 022415: Lowered (old value 10) to reduce time between probing points. //#define Z_PROBE_SLED // turn on if you have a z-probe mounted on a sled like those designed by Charles Bell //#define SLED_DOCKING_OFFSET 5 // the extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like. //If defined, the Probe servo will be turned on only during movement and then turned off to avoid jerk //The value is the delay to turn the servo off after powered on - depends on the servo speed; 300ms is good value, but you can try lower it. // You MUST HAVE the SERVO_ENDSTOPS defined to use here a value higher than zero otherwise your code will not compile. #define PROBE_SERVO_DEACTIVATION_DELAY 300 //* MindRealm 022415: Uncommented to quiet the ABL servo during moves and printing. //If you have enabled the Bed Auto Leveling and are using the same Z Probe for Z Homing, //it is highly recommended you let this Z_SAFE_HOMING enabled!!! #define Z_SAFE_HOMING // This feature is meant to avoid Z homing with probe outside the bed area. // When defined, it will: // - Allow Z homing only after X and Y homing AND stepper drivers still enabled // - If stepper drivers timeout, it will need X and Y homing again before Z homing // - Position the probe in a defined XY point before Z Homing when homing all axis (G28) // - Block Z homing only when the probe is outside bed area. #ifdef Z_SAFE_HOMING #define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28) #define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28) #endif //* MindRealm 022415: (FYI) This section is to provide feedback to the user when the defined probing area is too small. #ifdef AUTO_BED_LEVELING_GRID // Check if Probe_Offset * Grid Points is greater than Probing Range //* MindRealm 022415: (FYI) First check the X-axis probing points #if X_PROBE_OFFSET_FROM_EXTRUDER < 0 #if (-(X_PROBE_OFFSET_FROM_EXTRUDER * (AUTO_BED_LEVELING_GRID_POINTS-1)) >= (RIGHT_PROBE_BED_POSITION - LEFT_PROBE_BED_POSITION)) #error "The X axis probing range is not enough to fit all the points defined in AUTO_BED_LEVELING_GRID_POINTS" #endif #else #if ((X_PROBE_OFFSET_FROM_EXTRUDER * (AUTO_BED_LEVELING_GRID_POINTS-1)) >= (RIGHT_PROBE_BED_POSITION - LEFT_PROBE_BED_POSITION)) #error "The X axis probing range is not enough to fit all the points defined in AUTO_BED_LEVELING_GRID_POINTS" #endif #endif //* MindRealm 022415: (FYI) end of X_PROBE_OFFSET_FROM_EXTRUDER //* MindRealm 022415: (FYI) Then check the Y-axis probing points #if Y_PROBE_OFFSET_FROM_EXTRUDER < 0 #if (-(Y_PROBE_OFFSET_FROM_EXTRUDER * (AUTO_BED_LEVELING_GRID_POINTS-1)) >= (BACK_PROBE_BED_POSITION - FRONT_PROBE_BED_POSITION)) #error "The Y axis probing range is not enough to fit all the points defined in AUTO_BED_LEVELING_GRID_POINTS" #endif #else #if ((Y_PROBE_OFFSET_FROM_EXTRUDER * (AUTO_BED_LEVELING_GRID_POINTS-1)) >= (BACK_PROBE_BED_POSITION - FRONT_PROBE_BED_POSITION)) #error "The Y axis probing range is not enough to fit all the points defined in AUTO_BED_LEVELING_GRID_POINTS" #endif #endif //* MindRealm 022415: (FYI) end of Y_PROBE_OFFSET_FROM_EXTRUDER #endif #endif // ENABLE_AUTO_BED_LEVELING // The position of the homing switches #define MANUAL_HOME_POSITIONS //* MindRealm 022415: Uncommented to force 0,0,0 (front, left corner, on the glass) as the home position. //#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0) //Manual homing switch locations: // For deltabots this means top and center of the Cartesian print volume. #define MANUAL_X_HOME_POS 0 #define MANUAL_Y_HOME_POS 0 #define MANUAL_Z_HOME_POS 0 //#define MANUAL_Z_HOME_POS 402 // For delta: Distance between nozzle and print surface after homing. //// MOVEMENT SETTINGS #define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E #define HOMING_FEEDRATE {50*60, 50*60, 50, 0} // set the homing speeds (mm/min) // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,90} // default steps per unit for Ultimaker #define DEFAULT_MAX_FEEDRATE {250, 250, 2, 22} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {1000,1000,5,1000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for retracts // Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing). // The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder). // For the other hotends it is their distance from the extruder 0 hotend. // #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis // #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) #define DEFAULT_XYJERK 20.0 // (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec)
Re: ABL is not even worth it anymore February 24, 2015 11:34PM |
Re: ABL is not even worth it anymore February 24, 2015 11:41PM |
ggherbaz
Beside some things that need fixing in the endstop section (between homing and endstops) the main problem I see is that you are actually trying both types of leveling (grid and 3 point) that might be causing you all the problems, you need to comment "//" one of the two.
Danielis,
In your start G-code, where did you put G90? After G28 X0 Y0, or after G29?
Re: ABL is not even worth it anymore February 25, 2015 01:15AM |
Re: ABL is not even worth it anymore February 25, 2015 03:33PM |
Re: ABL is not even worth it anymore February 25, 2015 04:30PM |
ggherbaz
Yes, you need to comment either grid or 3 points, both cannot be activated at same time.
//============================= Bed Auto Leveling =========================== #define ENABLE_AUTO_BED_LEVELING //MindRealm: Commenting THIS line out turns off Auto Bed Leveling. (i.e. neither "grid" nor "3-point" modes will be active) //#define Z_PROBE_REPEATABILITY_TEST // If not commented out, Z-Probe Repeatability test will be included if Auto Bed Leveling is Enabled. #ifdef ENABLE_AUTO_BED_LEVELING // There are 2 different ways to pick the X and Y locations to probe: // - "grid" mode // Probe every point in a rectangular grid // You must specify the rectangle, and the density of sample points // This mode is preferred because there are more measurements. // It used to be called ACCURATE_BED_LEVELING but "grid" is more descriptive // - "3-point" mode // Probe 3 arbitrary points on the bed (that aren't colinear) // You must specify the X & Y coordinates of all 3 points #define AUTO_BED_LEVELING_GRID //MindRealm: Commenting THIS line out will turn off "grid" mode and fall back to "3-point" mode. // with AUTO_BED_LEVELING_GRID, the bed is sampled in a // AUTO_BED_LEVELING_GRID_POINTSxAUTO_BED_LEVELING_GRID_POINTS grid // and least squares solution is calculated // Note: this feature occupies 10'206 byte #ifdef AUTO_BED_LEVELING_GRID //MindRealm: THIS line checks whether AUTO_BED_LEVELING_GRID is defined. If so, it will look at the coordinates below to set the rectangle. // set the rectangle in which to probe #define LEFT_PROBE_BED_POSITION 10 #define RIGHT_PROBE_BED_POSITION 180 #define BACK_PROBE_BED_POSITION 165 #define FRONT_PROBE_BED_POSITION 10 // set the number of grid points per dimension // I wouldn't see a reason to go above 3 (=9 probing points on the bed) #define AUTO_BED_LEVELING_GRID_POINTS 3 //MindRealm: THIS line sets the number of points to be probed in each (X and Y) axis. This does not affect "3-point" mode. #else // not AUTO_BED_LEVELING_GRID //MindRealm: THIS line is the fall-back to "3-point" mode IF "grid" mode is NOT enabled. If "grid" mode IS enabled, this section is skipped. // Define 3 arbitrary points to probe. A simple cross-product is used to esimate the plane of the print bed #define ABL_PROBE_PT_1_X 60 #define ABL_PROBE_PT_1_Y 60 #define ABL_PROBE_PT_2_X 120 #define ABL_PROBE_PT_2_Y 60 #define ABL_PROBE_PT_3_X 90 #define ABL_PROBE_PT_3_Y 90 #endif // AUTO_BED_LEVELING_GRID
Re: ABL is not even worth it anymore February 25, 2015 09:55PM |
Re: ABL is not even worth it anymore February 25, 2015 09:57PM |
Re: ABL is not even worth it anymore February 25, 2015 10:10PM |
Nope wait that did not work just a fluke that it worked once I guessQuote
rdzmzda
So I think I came up with a fix. It is unorthodox to say the least but it seems to work. If I offset the print bead to where the first measurement is at the highest point then the last measurement is the lowest point it does not seem to drag. I get this is probably not ideal but it works..... I do not really know what else to do.
Re: ABL is not even worth it anymore February 25, 2015 11:21PM |
Re: ABL is not even worth it anymore March 01, 2015 12:27AM |
Re: ABL is not even worth it anymore March 01, 2015 04:50PM |
