Why Metric? February 25, 2015 05:52PM |
Re: Why Metric? February 25, 2015 07:38PM |
Re: Why Metric? February 25, 2015 07:39PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Why Metric? February 25, 2015 08:03PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Why Metric? February 25, 2015 08:27PM |
Re: Why Metric? February 25, 2015 08:54PM |
Re: Why Metric? February 25, 2015 09:21PM |
pushthatbolder
...I have tried importing using imperial and it makes the object 2.5 times bigger...
Re: Why Metric? February 25, 2015 10:25PM |
Re: Why Metric? February 25, 2015 10:33PM |
KingRahl
Metric is a base 10 system. Easy to calculate. Most of the time you read inches as a fraction. While you can reinvent the wheel just to suit your needs it won't be practical. You'll have to remember we are using a low level computer that has to do a lot of calculations on the fly as it is (changing coordinates into steps per cm) If you throw fractions into the mix, that's just something else to go wrong.
pushthatbolder
This is because there are 2.54 cm in 1 inch. The file was exported using a 1/1 scale.
Re: Why Metric? February 26, 2015 12:04AM |
Re: Why Metric? February 26, 2015 01:08AM |
Re: Why Metric? February 26, 2015 01:35AM |
pushthatbolder
Yes i know that. I was just stating it to support my post.. i know how measurement and numbers work
Re: Why Metric? February 26, 2015 05:28AM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: Why Metric? February 26, 2015 05:39AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Why Metric? February 26, 2015 05:54AM |
tmorris9
I am 50 and always worked in fractions and decimals. Since I got into 3D printing I am learning metric and I really, really wish the U.S. had switched over to metric like they said they were going to when I was in grade school.
Re: Why Metric? February 26, 2015 09:50AM |
Re: Why Metric? February 26, 2015 10:45AM |
elwood127
Sorry about the double post. I thought that I had deleted the first one. I guess not. Thanks for the replies. It sounds like it is time to conform or be cast out. Once again America is wrong thinking that it holds the high ground. That's why an earlier Mars mission inpacted the surface. One guy designing in mm's and another in inches. I'm going to buckle down and set Rhino up for mm's. Something new to learn and that's what it's all about.
Re: Why Metric? February 26, 2015 11:37AM |
No, it's just easier for humans because we inherently understand decimal. A computer doesn't do integer, float, or decimal arithmetic in base 10 anyways. It's just the ending result that is converted back to what we understand, base 10.Quote
KingRahl
Re: Why Metric? February 26, 2015 12:09PM |
Re: Why Metric? February 26, 2015 12:52PM |
Re: Why Metric? February 26, 2015 01:22PM |
KingRahl
pushthatbolder
Re: Why Metric? February 26, 2015 02:31PM |
Re: Why Metric? February 26, 2015 03:31PM |
jaguarking11
The answer is simple honestly.
Certain industries adapted one system globaly.
metric = just about every machined or produced article. Even cars built in the US use metric threads/bolts/nuts.
Standard = tiles, plumbing, and certain agricultural equipment.
The world is a mishmosh. At least we are down to small variations that are at least defined. Go look at mpg on a vehicle in the UK and a vehicle in the US. Same car gets higher MPG, the reason? The MPG standard in the UK is different than US.
Re: Why Metric? February 26, 2015 04:25PM |
Re: Why Metric? February 26, 2015 04:30PM |
tjb1
If you can't handle working with both units, you might not be cut out to be in manufacturing/engineering. It's pretty obvious when something is 1mm vs 1 inch...
Re: Why Metric? February 26, 2015 04:51PM |
tjb1
jaguarking11
Uh I work in a very large machine shop and we program everything in decimal inch and every other shop I have worked at used decimal inch. Using metric fasteners does not mean the item was produced with a metric print. Anything we share with other countries is done with dual dimensions.
Re: Why Metric? February 26, 2015 05:07PM |
Re: Why Metric? February 26, 2015 05:19PM |
tjb1
Re: Why Metric? February 26, 2015 08:59PM |
Re: Why Metric? February 26, 2015 10:11PM |
