Re: Why Metric? February 27, 2015 03:58AM |
Admin Registered: 16 years ago Posts: 13,889 |
Re: Why Metric? February 27, 2015 08:21AM |
jaguarking11
tjb1
jaguarking11
The answer is simple honestly.
Certain industries adapted one system globaly.
metric = just about every machined or produced article. Even cars built in the US use metric threads/bolts/nuts.
Standard = tiles, plumbing, and certain agricultural equipment.
The world is a mishmosh. At least we are down to small variations that are at least defined. Go look at mpg on a vehicle in the UK and a vehicle in the US. Same car gets higher MPG, the reason? The MPG standard in the UK is different than US.
Uh I work in a very large machine shop and we program everything in decimal inch and every other shop I have worked at used decimal inch. Using metric fasteners does not mean the item was produced with a metric print. Anything we share with other countries is done with dual dimensions.
If you can't handle working with both units, you might not be cut out to be in manufacturing/engineering. It's pretty obvious when something is 1mm vs 1 inch...
Yeah, your a US based machining shop. The world does not beggin or end with the US. I Have lived in the US all of my life, I went from grade school to college here. I am perfectly capable of doing conversions. With that said, the machining shops around the world that use only metric far outnumber the ones that do both or use only standard.
Personaly I am more adapt to doing things in metric than inches or fractions...... I was educated in the us with inches, feet etc. I own tools that are precise that measure in .001 inch, but at the end of the day my metric tools win out.
Re: Why Metric? February 27, 2015 03:48PM |
Jimmy Carter tried to tell us.....(go figure!)Quote
tmorris9
I am 50 and always worked in fractions and decimals. Since I got into 3D printing I am learning metric and I really, really wish the U.S. had switched over to metric like they said they were going to when I was in grade school. It is base 10 not 12 and it is just so much easier.
Re: Why Metric? February 27, 2015 04:16PM |
dclarkm
I'm sure you know, but the Imperial measurement system is hardly Base 12.....
Re: Why Metric? February 27, 2015 07:51PM |
