Different styles of printers March 02, 2015 10:54AM |
Re: Different styles of printers March 02, 2015 11:14AM |
Re: Different styles of printers March 02, 2015 11:22AM |
Re: Different styles of printers March 02, 2015 11:27AM |
ggherbaz
You are forgetting the new breed of scara printers that seems to combine the best of both worlds, but still to young and with some math and backslashes issues.
Zavashier
Scara of course and CoreXY.
Re: Different styles of printers March 02, 2015 11:53AM |
Re: Different styles of printers March 02, 2015 12:38PM |
Re: Different styles of printers March 02, 2015 01:44PM |
Zavashier
It isn't, a printer's architecture is different as long as the math to control it is different.
dc42
Don't worry about the math, that's taken care of by the firmware. The delta has some more advantages over Cartesian printers:
* More regular construction. You build 3 identical towers and carriage assembles, instead of building 3 different axes. Get one of them right and you get them all right.
* No issues with bed levelling, because the bed is fixed. Once you have done the delta calibration (which takes less than an hour even if you don't have a Z probe and a good auto calibration facility in the firmware), the machine is stable. It's much more difficult to keep the bed of a Cartesian printer level and stable because it moves.
* Smaller footprint for the same build area, because of the non moving bed. The delta needs more height, but that isn't usually an issue.
I have a Cartesian printer (Ormerod) and a delta (Mini Kossel, about to be enlarged). Based on my experience with them, I recommend the delta for its easier build, smaller footprint and faster print speed for the same print quality. I have no experience with CoreXY or Scara.
If you choose a delta then I strongly recommend you choose a 32-bit controller board for it. The 8-bit boards have barely enough power to do the delta calculations in spite of the approximations that firmware for 8-bity boards uses. Both my printers use 32-bit Duet electronics.
Re: Different styles of printers March 02, 2015 03:09PM |
Re: Different styles of printers March 02, 2015 03:35PM |
None of the methods are intrinsically more or less accurate for particular geometries. Any form of approximation made in software is orders of magnitude smaller than the physical resolution of the printer. By your logic (polar being bad at lines, cartesian being bad at curves), delta should suck at everything because any motion requires approximation using all three motors.
Polar can immediately be dumped because any system that relies on rotational axes for positioning has too many disadvantages in our price range (amplification of error, backlash, inertia).
There are plenty of existing discussions about cartesian vs delta. I think delta has a niche, but isn't great for large printers because the build volume is not efficient. It also has problems with loads that need a lot of space (multiple extruders).
The main source of faster print speeds in delta printers is the bowden+fixed bed. This can be emulated in cartesian printers, such as the ultimaker.
A delta printer will generally have much lower inertia than a cartesian printer because the arms can be very light. They do not undergo bending loads and are therefore extremely rigid in practice. Most consumers like deltas because they look cool.
The CoreXY is a variation of the H-Bot designed to compensate for poor rigidity, and uses a rather inelegant belt path. There are no high-end commercial implementations of the CoreXY- everyone uses h-bots (ex: stratasys).
Re: Different styles of printers March 02, 2015 04:35PM |
Re: Different styles of printers March 02, 2015 04:42PM |
pineapple
What do you mean by delta's not having an efficient build volume?
Re: Different styles of printers March 02, 2015 05:30PM |
Re: Different styles of printers March 03, 2015 03:38AM |
Re: Different styles of printers March 03, 2015 09:51AM |
Re: Different styles of printers March 03, 2015 10:27AM |
Re: Different styles of printers March 03, 2015 10:29AM |
Re: Different styles of printers March 03, 2015 11:29AM |
Re: Different styles of printers March 03, 2015 11:50AM |
Re: Different styles of printers March 03, 2015 01:16PM |
Re: Different styles of printers March 03, 2015 01:52PM |
Zavashier
7. The delta needs a bowden, so you probably won't be able to print exotic filaments, like filaflex.
8. The dela's head has a limited space, and that head is limited by weight too. So you probably won't be able to add a lot of features to your printer, like multiple extruders, a laser head, fans...
The delta have some advantages too, like a supported and fixed bed.
Re: Different styles of printers March 03, 2015 03:24PM |
ggherbaz
Pineapple,
I'm developing a scara printer, and like I posted at the beginning, they are quite simple in construction, a lot more sturdier than Cartesian and delta printers and with less moving parts.
The one I'm building is just for kids at school to see how vast and diverse 3d printing can be, it is fully 3d printed with exception of bearings, bolts and electronics. I don't care too much right now about its accuracy (kids don't mind) but it gives me a platform to work on. The main problem is gear backlash, which I'm reducing with plain opposite springs at the elbows and timing belts for power transmission.
The kind of gears and bearings used by real scara robots are expensive at this time, but if this type of printer progress, the costs will be reduced as it happened with cartesian ones and I think they will gain a lot more popularity than deltas or cartesian combined.
Re: Different styles of printers March 03, 2015 03:55PM |
Well I'm not a noodle expert, what about a review ? Some people says you can't extrude with enough precision flexible filaments on a bowden extruder, because of the compression applied to the filament. I must confess that seems logical to me too. That's why I did not tryed flexible filaments on my bowden setting yet. I also don't need flexible prints very often. Honnestly, I just give my spool some trys, then it's on the shelve since 4 months now.Quote
jaguarking11
Zavashier
I Disagree on the multiple extruders sentiment. You can design a delta with multiple extruders and it will function properly. Each extruder will have to be bowden fed.
I also disagree on the flexible filament sentiment. That is more of a function of the extruder than anything else. A proper extruder would not have issues pushing flexible filament down a bowden tube, unless the filament is sticky by nature. I am fairly sure that with a proper extruder you can push a wet noodle through a bowden tube.
Re: Different styles of printers March 03, 2015 06:38PM |
Re: Different styles of printers March 04, 2015 06:25AM |
dc42
But all good 3D printer designs have a resolution much better than the width of the nozzle, so I suggest you ignore print resolution in your deliberations.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Different styles of printers March 04, 2015 07:16AM |
Re: Different styles of printers March 04, 2015 10:49AM |
ggherbaz
Pineapple,
You just answered the question.
The scara robot I have seen, moves thousands of times in a day, they need to be extremely precise and efficient, usually gear reductions from 50:1 or more packet in small sizes requires high tolerances and special alloys to prevent backlash, high precision and speed bearings that allows the arms moves without wobble millions of times in their life span.
Electronics manufacturers count their rejects in 1 per millon or less, the only way to achieve that is with extreme precision and advanced materials.
Re: Different styles of printers March 04, 2015 10:52AM |
Re: Different styles of printers March 04, 2015 11:12AM |
Re: Different styles of printers March 04, 2015 12:14PM |
Re: Different styles of printers March 04, 2015 01:47PM |
Also note that print quality requires repeatability much better than the nozzle diameter.
The human eye can perceive inconsistencies well below 0.01mm. For good looking prints you must be able to perfectly line up successive layers.
