Wood Filament
April 10, 2015 07:03PM
Any Experience with Wood Filament anybody?
Is it possible to make any common printer, like the Rosell or the Delta into a wood filament printer?
I assume you have to change the extruder, and change some voltageS?
Re: Wood Filament
April 10, 2015 11:39PM
Just don't do what I did and try to use a 0.4mm nozzle.
Re: Wood Filament
April 11, 2015 04:58AM
What happened with a .4 nozzle?
Re: Wood Filament
April 11, 2015 07:39AM
@Some laywood it works with 0.4mm nozzle. But 0.5 seems very stable.
Well it cloggs. The wood particles get burned a little bit (thats why you can change to darker color with temperature).
I tried with 0.3mm nozzle and it just wont work. Just a few minutes then its clogged. You can get it free with some thin steel wire (e.g. guitarstring) but it will clogg again!
Get yourself a 0.5mm nozzle. Things look great even with that size.
Laywood
Re: Wood Filament
April 11, 2015 10:33AM
Sweet. Which printer do you have?
On the ebay listing for the one I'm looking at, it says the heat bed requires 230 C and this model the heat bed only goes to 110, what a turn off!
The printer is a i3 Geeetech Pro B
Whats your experience with the heat bed?
Re: Wood Filament
April 11, 2015 05:25PM
Temperature fot the hotend is app. between 180 -250 degrees.
There is no heatedbed necesarry.
Re: Wood Filament
April 11, 2015 07:24PM
You wont need a heated bed for laywood.
Edit:
Ok you can use a heated bed with kapton or sugarwater (yes!). Printbedtemp like PLA works fine (50-60°C).
My printer is a German RepRap Neo. But i doesnt matter. Any standard FDM/FFM printer works due to the relativly low print temp winking smiley
Edited 1 time(s). Last edit at 04/12/2015 02:51PM by Lord_Vader.
