Unable to center print
April 25, 2015 09:45AM
The printer head goes 45 degrees from the start point
to the other side of the bed and will not stop unless
I hit the kill button. Printer will stop at edge of
bed in manual mode. Seems to do with the slicing
software. Same results with Slic3r and CuraEngine. Any ideas?
Re: Unable to center print
April 25, 2015 10:20AM
Have you run the calibration tests?
For me home is front left corner (left corner closest to me) as thats where the platform and head hit the endstops.
Edited 1 time(s). Last edit at 04/25/2015 10:22AM by GRAYWOLF.
April 26, 2015 09:06AM
If you can drive it manually with success it sounds like either your bed size or zero point location is not configured in your slicer to match your machine hardware/firmware configuration.
April 26, 2015 09:53AM
I move the printer to another computer. It now moves to the center and starts printing. Your probably correct in the configuration not matching. Thank You for your support
May 01, 2015 09:14PM
Solution.......Changed to the settings in the attached image....
open | download - working.jpg (119.3 KB)
