Aluminium linear rails instead of steel rods: your (negative) experiences? May 11, 2015 08:25PM |
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 12, 2015 08:41AM |
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 12, 2015 09:20AM |
It's obvious that you haven't looked into how obvious it is (or isn't). Without stating all sorts of things like dimensions, profile, alloy, wear surfaces, type of wear (linear bearing, bushing, wheel, etc) it's not at all obvious. In many cases aluminum may be a better choice than stainless steel. It can be lighter, cheaper, easier to machine, and harder surface than stainless steel. Stainless steels advantage is it's corrosion resistance which as long as you take care of your printer, really isn't a concern unless you're printing next to an ocean.Quote
cristian
It is obvious that stainless steel lasts much longer and is sturdier than aluminium
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 12, 2015 11:06AM |
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 12, 2015 12:52PM |
Short answer is reduced cost (hopefully) and complexity. Using extrusion allows you to reduce your part count. If you can use extrusion that is Good Enough™ for both structural support and linear movement, you kill two birds with one stone. No it might not be the greatest and most precise, but for many the trade offs or limitations are acceptable.Quote
691175002
Why bother with extrusion when the correct components are easily available?
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 12, 2015 02:44PM |
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 12, 2015 03:52PM |
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 12, 2015 05:17PM |
cdru
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 13, 2015 12:31AM |
cdru
691175002
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 13, 2015 09:57AM |
It's going to depend very much on the what design you're using and how exactly you count things. How are things fastened? Number of fasteners? Are standoffs used or are the rods/extrusion an integral component of the overall frame?Quote
thetazzbot
using extrusion does not reduce parts count at all.
one rod, two linear bearings.... three parts, compared to one extrusion, mounting hardware, and roller mechanism which, if printed parts involved, already will be more complicated.
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 13, 2015 10:34AM |
I agree with you mostly with what you wrote (including what I didn't include in the quote). And that's what I've done with my personal printer when I made my Mendel90 (although I must admit some of my initial attempts at "improvements" weren't so much).Quote
the_digital_dentist
If you were trying to design a printer to be sold as a kit and you were competing with 1000 other kit makers on price, I could understand your motivation to shave a few dollars out of the cost of the machine. If you're building a machine for yourself, presumably there's something you want to do that isn't readily available. Is cost the only factor driving the DIY impulse? Kits are only $300. You're going to have a hard time building for less than that yourself and you'll end up spending many hours chasing ever cheaper parts and figuring out how to incorporate them. So if you're building a machine yourself, why not do it right instead of cheap?
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 13, 2015 12:48PM |
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 13, 2015 05:28PM |
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 13, 2015 11:39PM |
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 14, 2015 01:02AM |
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 14, 2015 06:36AM |
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 14, 2015 07:57AM |
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 14, 2015 09:20AM |
If you want an actual number for what the tolerance is, I can't help you any more than what koko76 said with a dial indicator and a surface plate. But if you're asking these questions I'm going to guess you don't already have a surface plate, nor do you want to spend the chunk of change to get one.Quote
cristian
But here is another question then: how do you measure the precision of parts, if the vendor is not providing already this information? Measuring distances and diameters is easy in most of the cases, with a good caliper. But what if I wanted to measure (and I mean really measure, not just get a sense of) the tolerance of the straightness of an aluminum profile or of a stainless steel smooth rod, how may I do that? What about the twist?
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 14, 2015 10:40AM |
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 14, 2015 12:29PM |
Technically a dial gauge will measure the width/height of the extrusion as well as its straightness so you may overestimate the error.
Re: Aluminium linear rails instead of steel rods: your (negative) experiences? May 14, 2015 01:22PM |
