Seeking resistor heater recommendations May 19, 2015 02:37PM |
Re: Seeking resistor heater recommendations May 19, 2015 02:48PM |
Re: Seeking resistor heater recommendations May 19, 2015 02:52PM |
Re: Seeking resistor heater recommendations May 19, 2015 03:22PM |
Re: Seeking resistor heater recommendations May 19, 2015 03:38PM |
Or perhaps you need to find a better source especially if the 4 of 5 came from the same batch and/or source. I've never had an issue with a cartridge heater failing. The only time that I've ever had to replace them is for design considerations.Quote
leadinglights
I tried heater cartridges when they first came out but had 4 failures out of 5 - one burned out after ca 20 hours, one case short, one open circuit and one with a resistance of 13 Ohms. I would prefer to stick to resistors until I am convinced that there is a quality product on the market..
Re: Seeking resistor heater recommendations May 19, 2015 04:06PM |
Re: Seeking resistor heater recommendations May 20, 2015 02:51AM |
Re: Seeking resistor heater recommendations May 20, 2015 04:55AM |
leadinglights
I use 24V as far as possible and have not yet seen smaller cartridges in 24V.
Re: Seeking resistor heater recommendations May 20, 2015 06:49AM |
Re: Seeking resistor heater recommendations May 20, 2015 09:27AM |
leadinglights
Thanks dc42, I will send for one from RepRapPro to try. I suspect though that in the end I will in the end keep to resistors - one by Vishay (part number RWM041022ROJR15E1) is categorized all the way up to 450C.
leadinglights
o_lampe, The resistance of an aluminum hot end block made from a 1cm cube would be about 28 microOhms so to get it to dissipate 20 watts would take 2670 Amps - the wires would be too thick for me.
Re: Seeking resistor heater recommendations May 21, 2015 04:48AM |
dc42
leadinglights
450C is a good maximum temperature, and the price is good too (GBP0.43 from Farnell). Getting good thermal contact between the resistor and the heater block won't be easy though, and I don't think the usual thermal transfer pastes are any good at those temperatures.
