Teacup: firmware made simple, newbies wanted June 01, 2015 08:35AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Teacup: firmware made simple, newbies wanted June 01, 2015 09:23AM |
Re: Teacup: firmware made simple, newbies wanted June 01, 2015 10:51AM |
cdru
Damn all those firmwares that break the laws of physics!
Re: Teacup: firmware made simple, newbies wanted June 01, 2015 11:02AM |
youssefaly97
Hello, I was wondering how well are LCD and button controlls are working in Teacup as well as the SD card ?
Re: Teacup: firmware made simple, newbies wanted June 01, 2015 11:04AM |
Re: Teacup: firmware made simple, newbies wanted June 01, 2015 11:49AM |
o_lampe
If it follows the laws of physic, why does a newbie user have to fill in all the acceleration/max/min -stuff? I expect a one button GUI, called autotune and that´s it
-Olaf
Re: Teacup: firmware made simple, newbies wanted June 01, 2015 12:06PM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: Teacup: firmware made simple, newbies wanted June 01, 2015 12:15PM |
o_lampe
Re: Teacup: firmware made simple, newbies wanted June 01, 2015 01:04PM |
Re: Teacup: firmware made simple, newbies wanted June 07, 2015 06:55AM |
Re: Teacup: firmware made simple, newbies wanted June 07, 2015 07:20AM |
Re: Teacup: firmware made simple, newbies wanted June 07, 2015 07:51AM |
AndrewBCN
Note that I fully understand that there is a need to keep the main Teacup code as small as possible, so take all my wishes as optional compile-time modules where applicable.
AndrewBCN
1. LCD support for two LCD controller types, the standard LCD2004 Smart controller panel, and the Full Graphics 12864 Controller.
AndrewBCN
2. Delta kinematics support, fully debugged and performance optimized.
AndrewBCN
3. Indeed, jerk control would be nice if it can be implemented elegantly enough.
AndrewBCN
4. A fully supported 32-bit version of Teacup for me to experiment on my Due + hacked RAMPS setup.
AndrewBCN
5. Support for M80/M81 to be able to remotely turn on/off the PSUs in my printers.
AndrewBCN
6. Support for M119 limit switch status reporting.
AndrewBCN
7. Support for M500/M501/M502 EEPROM related commands.
Re: Teacup: firmware made simple, newbies wanted June 21, 2015 11:07AM |
madmike8
Congrats, If I can fin someone to make one of those SinapTec boards I'm going to put this to use...
Re: Teacup: firmware made simple, newbies wanted July 14, 2015 05:40PM |
Admin Registered: 13 years ago Posts: 730 |
Re: Teacup: firmware made simple, newbies wanted July 14, 2015 07:14PM |
Admin Registered: 11 years ago Posts: 1,063 |
tatubias
madmike8
We have received from a company that makes pcb 3 samples.
Yesterday we ( lets be realistic inapTec, lol..) have finished soldering the components on the board, we will be performing new test and letting know the status. I have not received the board yet. Due i live like 700kms from sinaptec home. Also the company that did se t us the board is lime 400km from sinaptec home.
Here its the new picture of the board.
reprap.org/wiki/SinapTec
Regarding the config file i did created and posted some were here in the forum. but i have not tested yet.
Re: Teacup: firmware made simple, newbies wanted July 14, 2015 09:23PM |
Re: Teacup: firmware made simple, newbies wanted July 14, 2015 09:39PM |
JamesK
You must have some awesome ideas for what you want to do with all that horsepowerQuote
and in the future something like an xmos chip or even something fpga driven in the future
Re: Teacup: firmware made simple, newbies wanted July 15, 2015 05:41AM |
JamesK
MattMoses
Is Teacup Configtool eligible for bobc's bounty on the RepRap-meta-proto issue tracker?
Bounty described here: Create a configuration tool for RepRap firmware
Re: Teacup: firmware made simple, newbies wanted July 19, 2015 08:28AM |
Re: Teacup: firmware made simple, newbies wanted July 19, 2015 11:31AM |
Re: Teacup: firmware made simple, newbies wanted July 19, 2015 01:53PM |
Re: Teacup: firmware made simple, newbies wanted September 02, 2015 07:52AM |
Re: Teacup: firmware made simple, newbies wanted September 02, 2015 08:32AM |
Re: Teacup: firmware made simple, newbies wanted September 02, 2015 02:42PM |
Re: Teacup: firmware made simple, newbies wanted September 02, 2015 03:56PM |
benj919
Or is the TT_intercom a special setting telling teacup to send and receive all temp data to/from the extruder board?
Re: Teacup: firmware made simple, newbies wanted September 04, 2015 08:09PM |
Heaters
Name Pin PWM bed AIO0 False extruder AIO1 False
Temperature Sensors
Name Type Pin bed TT_INTERCOM AIO0 extruder TT_INTERCOM AIO0
Re: Teacup: firmware made simple, newbies wanted September 05, 2015 01:09PM |
Heaters
Temperature Sensors
Heaters
Name Pin PWM extruder AIO0 False bed AIO1 False
Temperature Sensors
Name Type Pin extruder TT_INTERCOM AIO0 bed TT_INTERCOM AIO1
Re: Teacup: firmware made simple, newbies wanted February 24, 2018 01:30PM |
