Heatbed relay questions June 07, 2015 04:33AM |
Re: Heatbed relay questions June 07, 2015 08:26AM |
Re: Heatbed relay questions June 07, 2015 08:52AM |
Re: Heatbed relay questions June 07, 2015 09:36AM |
Re: Heatbed relay questions June 07, 2015 11:12AM |
Re: Heatbed relay questions June 07, 2015 01:52PM |
the_digital_dentist
Not sure about DC SSRs, but the SSR I use to switch the 5A or so AC into the transformer under PID control has no heatsink and doesn't get warm.
1. Would it be necessary to control the heatbed via PID? I have mine in bang-bang mode and that would work too for the big SSD-controlled one?!
2. When a SSD relais gets hot, would it be possible to put it under the aluminum bed acting as heatsink? 110°C would be OK for the SSD?
Re: Heatbed relay questions June 07, 2015 03:47PM |
Re: Heatbed relay questions June 07, 2015 06:30PM |
Re: Heatbed relay questions June 08, 2015 04:12AM |
itchytweed
Running my heat bed (14 volts, 32 amps) using just an IRF4905 mosfet and a small heatsink from a celeron processor in PID mode. Barely gets warm.
Re: Heatbed relay questions June 12, 2015 02:41AM |
Re: Heatbed relay questions June 20, 2015 05:26PM |
Re: Heatbed relay questions June 21, 2015 03:41AM |
Re: Heatbed relay questions June 22, 2015 02:18AM |
