Faster heatup
June 08, 2015 04:36AM
Hi
Im kinda bored of the long heatup times of my heated bed. So what are the possibilities i have.
My Mainboard is a smoothiebard
Edited 1 time(s). Last edit at 06/08/2015 04:39AM by Fuselium.
Re: Faster heatup
June 08, 2015 07:46AM
I don't know. Start by opening up the valve on the propane cylinder a little more...
Too bored to provide any useful information?
Re: Faster heatup
June 08, 2015 08:07AM
Get a bed with higher wattage or increase the voltage. I don't know if the smoothie board supports higher voltages, i had no problem doing that with my Rumba. Be aware that you will very likely need to limit PWM quite a bit if you go for 24 V instead of 12.
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
Re: Faster heatup
June 08, 2015 08:09AM
What power supply are you using? Can you turn up the voltage a little?
Re: Faster heatup
June 08, 2015 08:10AM
Im using a 12v 30a Power supply
Re: Faster heatup
June 08, 2015 08:21AM
Fuselium
That's a good start.
And the heater is ? How long does it take to get bored to heat up the bed?
If you want people to help you, you have to provide all the relevant info.
Edited 2 time(s). Last edit at 06/08/2015 08:31AM by the_digital_dentist.
Re: Faster heatup
June 08, 2015 08:58AM
Reduce mass or increase power (which means increase voltage and/or current)
Re: Faster heatup
June 08, 2015 09:20AM
It takes like 15min to heated up to100°C. I have a Glas plate on the mk2a heated bed.
How can i increase Voltage
Re: Faster heatup
June 08, 2015 09:47AM
Some switching power supplies have a small potentiometer to adjust the output voltage, but be careful. Power/current increases rapidly with increased voltage and you can easily push the supply beyond its limits and kill it.
What is the power rating of the heater?
Re: Faster heatup
June 08, 2015 09:52AM
I dont Know it is baught from ebay
Re: Faster heatup
June 08, 2015 12:36PM
The best suggestion so far would be this
3d printer heated bed heats too slow
But in all seriousness, from what you've told us so far:
1. You have a cheap chinese kit printer
2. That printer has a cheap PCB heater that cannot get past 100 (i have one too)
3. You're bored with the heat up time. (me too)
What I've done to over come this:
1. As soon as I decide I want to start messing with my printer, I warm up the bed.
2. Then I go gather my files, start messing with the slicing settings.
3. The bed has normally gotten to temp by now, so I'm ready to print.
4. I don't tend to leave the printer unattended for long periods. The machine didn't come with insurance.
If you've got some money, buy a polyimide film heater from ebay. $40-$150 US depending on seller and specific attributes. Need 150 Watt. Some run off 12v, 24v, house mains, etc.
google it: polyimide film heater
Edited 2 time(s). Last edit at 06/08/2015 12:43PM by thetazzbot.
