Extruder overheating and slipping? June 22, 2015 02:57AM |
Re: Extruder overheating and slipping? June 22, 2015 03:18AM |
Re: Extruder overheating and slipping? June 24, 2015 01:23AM |
Re: Extruder overheating and slipping? June 26, 2015 03:22PM |
Re: Extruder overheating and slipping? June 28, 2015 06:55PM |
Re: Extruder overheating and slipping? June 28, 2015 08:50PM |
Re: Extruder overheating and slipping? June 29, 2015 12:28AM |
Re: Extruder overheating and slipping? June 29, 2015 12:49AM |
Re: Extruder overheating and slipping? June 29, 2015 02:12AM |
jbernardis
Your message isn't clear here. It sounds like it's not the hot end overheating, but the motor. If it IS the motor, then it is overheating because you are overdriving it. This same thing happened to me; the motor overheated to the point where the small gear and the extruder body both deformed. Also, I couldn't touch the motor for more than a second or two.
My solution was to dial back the current a bit on the stepper driver. Now the motor barely gets warm and it NEVER slips.
ABSQuote
jamesdanielv
what kind of plastic are you using as feedstock? if you are using pla then the temp needs to be lower.
