Repetier is making fun of me! June 24, 2015 10:06AM |
Re: Repetier is making fun of me! June 24, 2015 10:49AM |
Re: Repetier is making fun of me! June 24, 2015 11:12AM |
Re: Repetier is making fun of me! June 24, 2015 01:03PM |
Re: Repetier is making fun of me! June 24, 2015 01:17PM |
Re: Repetier is making fun of me! June 24, 2015 01:30PM |
Re: Repetier is making fun of me! June 24, 2015 01:31PM |
CraigMoberg
What temperature do you have the extruder set at in your slicer? It sounds like the gcode thinks the temperature should be much lower. This is generated by the slicer, and once the print starts, it overrides your manual temperature setting. "Heating extruder" really means "Getting extruder to target temperature." When the print starts, you should see a vertical line somewhere along the extruder temperature scale in Repetier, showing the target temp.
I don't know why it would be heating up fine and then drop in the middle of a print, though. But check your slicer settings anyway.
Re: Repetier is making fun of me! June 24, 2015 01:34PM |
markts
Does it never heat the extruder? It stays at room temp? How long did you wait?
How about if you change the settings so it doesn't have to heat the bed?
Depending on how long you waited, this still sounds like how mine behaves.
Re: Repetier is making fun of me! June 24, 2015 01:35PM |
Re: Repetier is making fun of me! June 24, 2015 01:40PM |
Re: Repetier is making fun of me! June 24, 2015 02:09PM |
Re: Repetier is making fun of me! June 24, 2015 02:15PM |
Re: Repetier is making fun of me! June 24, 2015 02:40PM |
tadawson
Sorry, I can't give you specifics since I don't run Repetier, but there should be a communication feature that allows you to talk directly to the printer, and also see what gcode/messaging is going back and forth, and I will defer to others to procide you the specifics. I have heard this discussed regarding Repetier, so am certain that the function is there . . . (In Pronterface, for example, it's a field on the main screen . . .)
- Tim
Re: Repetier is making fun of me! June 24, 2015 03:12PM |
southenprinter
markts
So room temp is about 19-20C. I start the print some 10 min ago and in that period it rose to 25C.
Re: Repetier is making fun of me! June 24, 2015 03:22PM |
markts
southenprinter
markts
Was the bed up to temp?
Re: Repetier is making fun of me! June 24, 2015 03:28PM |
southenprinter
tadawson
- Tim
I found out how, but it didnt work
Re: Repetier is making fun of me! June 24, 2015 03:37PM |
tadawson
southenprinter
tadawson
- Tim
Didn't work as in no heat, or sending the command errored? If the printer will take the command and then does nothing, then you have pretty much isolated this to a hardware or firmware problem.
Does it heat with M104 S185?
If that works, and then M109 S185 causes it to stop heating, then your firmware is borked, plain and simple . . .
- Tim
Re: Repetier is making fun of me! June 24, 2015 03:40PM |
Re: Repetier is making fun of me! June 25, 2015 08:45AM |
Re: Repetier is making fun of me! June 25, 2015 11:30AM |
Re: Repetier is making fun of me! June 26, 2015 09:03AM |
tadawson
I know that in most slicers, if you put custom gcode in for temp, it will override what the slicer tries to send otherwise, but that in no way should have prevented the manual commands from causing the hearters to turn on, unless Repetier is doing some really odd stuff . . .
What, if I may pry, did you need to add or remove from the custom G code?
- Tim
Re: Repetier is making fun of me! June 26, 2015 10:50AM |
Re: Repetier is making fun of me! June 27, 2015 01:22PM |
tadawson
Slicers almost always embed the temp lines, and it's very common for a temp change after the first few layers, which often run hotter (not sure about mid-print though). I have the M104, M109, M104 sequence in the gcode of everything I print, and it works . . . . I have a temp calibration piece that I use with 10 temp changes in it! None cause a shutdown . . .
I still think the problem here is in your firmware . . . this *should* work!
- Tim
Re: Repetier is making fun of me! June 27, 2015 01:25PM |
Re: Repetier is making fun of me! June 28, 2015 06:43PM |
Re: Repetier is making fun of me! June 30, 2015 08:22AM |
elwood127
For what it's worth, I just downloaded Slic3r 1.2.9 and am seeing something similar. I preheat using manual control and after hitting "Print" the hotend temp drops until the Z preprint motion starts then it begins to rise and then prints when back up to temp.
Re: Repetier is making fun of me! June 30, 2015 08:55AM |
tadawson
Read, read, read, and read some more! Then configure, build, and load firmware that you know is correct. Possibly, someone here with the same printer might donate you a kmown-good config.
- Tim
Re: Repetier is making fun of me! June 30, 2015 10:45PM |
Re: Repetier is making fun of me! July 01, 2015 09:00AM |
Re: Repetier is making fun of me! July 01, 2015 10:31AM |
southenprinter
Is there any way i can see whats going on the firmware without changing it? I did a little googling and only saw how to upload a new firmware to the printer. The one that it currently has is Repetier 0.91. I wouldn't like to change it because it might make things worse.
