Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 04, 2015 09:53AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 04, 2015 10:25AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 04, 2015 10:33AM |
madmike8
Using the NO (Normally Open) NPN sensor I have Wired Normally
Brown - 12v
Blue - Ground
Black - Signal
I get 11.5v No LED without metal near sensor. Bright LED and 0v with metal near sensor. Too much V to directly connect to RAMPS.
Wiring this way
Brown - 12v
Black - Ground
Blue - Signal
I get Dim LED 2.84v without metal near sensor. Bright LED and 0v with metal near sensor.
Wired this way, I connected the blue directly to RAMPS Zmin Signal and it worked.
Hope that helps clarify.
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 04, 2015 05:45PM |
NarimaanV
madmike8
Brown - 12v
Blue - Ground
Black - Signal
Wiring this way
Brown - 12v
Black - Ground
Blue - Signal
What is the wiring layout of your sensor? Is it Brown = Power, Black = Output Signal, and Blue = Ground?
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 04, 2015 07:13PM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 05, 2015 10:24AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 05, 2015 10:45AM |
JBFUK
I wasn't sure as I got 12V on the sensor output when testing. Just to be safe I connected to the voltage divider I'd previously used for my inductive sensor. Works so I'll leave it like that for now.
BTW the LJC18A3-H-Z/BX works great with my glass plate. Highly recommended. I just wish it was smaller like the 8mm diameter inductive sensor.
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 06, 2015 12:56PM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 06, 2015 09:26PM |
JBFUK
No I simply powered with 12v via the brown and blue wires and then measured the voltage between the black output wire and ground when activated. I take it this is not an accurate interpretation of what RAMPS would see if I connected that black wire directly to it? Wouldn't mind getting rid of the little voltage divider circuit if I could it would tidy things up a bit.
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 07, 2015 07:14AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 07, 2015 03:36PM |
JBFUK
I see, the difference is connecting the black line to ground and using the blue line as the endstop input as opposed to the other way around which is what the sensor wiring diagram on the device itself shows. I'll switch to doing that once I've printed out a RAMPS enclosure and tidy up my wiring.
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 08, 2015 06:44AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 08, 2015 06:59AM |
JBFUK
I'm not sure and to be honest I just don't want to have another broken component to replace. I already suffered a blown PSU and MOSFET on the bed feed when the heatbed managed to short itself out - the washers above the bed spring slowly wore through the PCB coating and resulted in a short via the frame! Could be a blessing in disguise as I replaced the MOSFET with a much higher rated component which doesn't even get warm in use. Still it's annoying to have to wait days for a replacement part, disassemble etc etc.
Think I'll leave it how it is for now and focus on tuning my prints. Very happy to be back on glass as opposed to an ali build plate.
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 09, 2015 07:26AM |
NarimaanV
I think people use the inductive sensors for the advantages of a metal bed as well as opposed to just inductive vs capacitive. And if you already have a metal bed, I'd imagine inductive is probably better to go for than capacitive (don't know for sure, but I think capacitive is slightly open to interference by other stuff near the sensor where as inductive mainly pics up only metallic surfaces).
As for NPN vs PNP, I don't know exactly why they go for PNP, I think it might have to do with Printrbot's inductive sensor being infamous for being reliable and it happens to be a PNP sensor, so people might go for that over others because there are lots of reviews saying good things about it.
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? January 27, 2016 01:07PM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? January 27, 2016 01:44PM |
usen
I use it in cartesian 3d printer type. I modified g-codes for Z-Probe with NPN Capacitive Proximity Sensor (LJC18A3-B-Z/BX).
I measure capacitive sensor data from multimeter:
Input: 11.64 Volt
Signal: 3.80 Volt
Sensor Output: 9.72 Volt
Is there any problem?
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? January 27, 2016 02:12PM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? January 27, 2016 05:36PM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? January 29, 2016 07:37AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? January 29, 2016 11:03AM |
usen
When it's not triggered, it is 0.91V. Is it enough (3,80 volt) when it is triggered? Because, capacitive sensor doesn't work well everytime.
I watched this video: [www.youtube.com] and I use 15k and 10k resistors like below:
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? January 30, 2016 06:05AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? January 30, 2016 01:03PM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? January 30, 2016 01:35PM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? January 30, 2016 02:07PM |
usen
When it is not triggered;
11,82V (Sensor Output) and 0,62V (Signal Output from Sensor)
11,84V (Sensor Output Reach to Ramps 1.4) and 0,92V (Signal Reach to Ramps 1.4)
When it is triggered;
9,31V (Sensor Output) and 2,66V (Signal Output from Sensor)
11,97V (Sensor Output Reach to Ramps 1.4) and 3,81V (Signal Reach to Ramps 1.4)
realthor
Hello, I was thinking of going capacitive for a while now but something doesn't click.
We need to measure bed level at nozzle height when nozzle is heated up right? How do you place such a bulky piece of hardware close enough to the nozzle so it performs its function properly? How far is too far?
That was for horizontal placement. Now for vertical placement and setup you should first know the offset from the heated nozzle tip. How do you measure that? And how do you factor in the sensor's own error?
I don't know why but this all probing and leveling should really be done between the heated nozzle tip and the bed. There should be a way to accurately measure when the nozzle touches the bed. Put current in the nozzle, current in the bed, at contact register ...Ok this might be overly simplistic and maybe naive/dangerous, but you get the point.
I have the Overlord Pro and although the auto-bed leveling is not performing as anticipated (I greatly put that on software), it's doing probeless auto-bed leveling quite smart. And now that is open source, maybe that can be replicated.
ElmoC
The M212 command used in the video is for Marlin. Other firmware may do it differently, but they all function the same. It sets the height of the tip on the hotend from the bed when the sensor triggers. You adjust this value until the first layer is put down correctly.
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? January 30, 2016 03:59PM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? January 31, 2016 08:42PM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? January 31, 2016 08:53PM |
realthor
Does the bed loose leveling after once manually leveled to justify carrying a probe around and doing the leveling at each print?
I think people should better think this hard about a good structure before auto level compensation. I am sorry but all this focus on probes seems to me a good way for people to avoid the more painful thinking about what is in fact wrong.
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? February 11, 2016 01:45AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? February 11, 2016 03:07AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? February 11, 2016 04:01AM |
bigfilsing
and dont forget auto bed leveling means the z axis will be constantly moving during a print !!! Im not confident that M5 threaded rod ( typical Prusa i3) and stock nut will handle that constant movement well.
Even on my Prusa Air 2 where i have ball screws on the Z axis im still on the fence as to the relative advantages of auto bed leveling . Just my 2 cents
