What's your firmware?
If you are using Marlin (most common), you can use this edit:
1) Find the M109 Tn Sxxx commands for the extruders near the beginning, and copy those to a clipboard.
2) For each M109 Tn Sxxx, search for all 'Tn' commands (on a single line), and replace with:
M109 S0 ; Allow current extruder to start cooling down
M109 Tn Sxxx ; Bring other extruder up to temperature
Tn ; Select new extruder
That _should_ work for Marlin. See the GCode page on the wiki for equivalent commands for other firmwares.
(for example, on RepRap Firmware, you'd simply set the 'idle' temperature in your G10 tool definition command to 0,
make sure you have a 'M116' after every 'Tn', and all this would happen automatically).
http://reprap.org/wiki/G-code
