Local makerspace gone mad :-D
September 03, 2015 10:13AM
Hi all
The local makerspace has gone mad
They want to build a 3d printer that has a 600*600 build plate and 600mm movement for the Z axis
Insane yes, but at least its not my idea, but i want to play along just for the fun of it
With that size plate it cant be a moving one as it will be to much mass to move
So far i have thought of a delta or a H bot.... for the delta's a i have looked at open beam etc but there are not many plans or scripts that can provide a build plan
Any pointers etc are much welcome
BTW speed is not the goal... the goal is producing quality prints.... and yes large prints takes time i know
Re: Local makerspace gone mad :-D
September 03, 2015 01:13PM
I believe that SeeMeCNC built a large scale delta with a pellet feeder rather than traditional filament. Not sure how big it was, but they printed a small, lifesize boy out. They might be able to provide you with some information or plans.
I think a few rostock or kossel printers on Thingiverse come with OpenSCAD plans that you can scale up.
September 03, 2015 01:35PM
I don't see anything insane about it, unless they're going to use MDF or laser cut acrylic for the frame.
September 03, 2015 01:46PM
nothing have been decided yet
personal i would pick metal all round and as little printed parts as possible. pref none
September 03, 2015 02:32PM
I would vote for a H bot. Maybe borrow a bar a or two from here for the frame. Inexpensive, simple and reasonably sturdy.
Cheers!
September 03, 2015 02:41PM
To build a delta with 600mm build diameter (so not quite 600x600), you will need diagonal rods about 700mm long. To get 600mm build height, you need a machine height of about 600 + 700 + 200mm = 1.5m. Not too high to be practical, but pushing the envelope. If you want to build it as a delta, take a look at scaling up the large (300mm diameter x about 500mm high) design described in my blog (see my signature). Some points to note:
- With a delta of that size, 2020 extrusions are probably too small. Go for 2040 or 2060 instead.
- Likewise, you should use thicker carbon fibre tubes.
- Don't even consider using printed corners. Go for metal corners. Robotdigg sells expensive solid aluminum ones, and I am told they have a version for 2040 extrusion now. Alternatively, check out this thread [groups.google.com] for less expensive sheet metal corners.
- Increase the spacing of the diagonal rods to about 90-110mm, to increase the rigidity of the effector.
You may be better off choosing an H-bot design, but I have no experience of those.
September 06, 2015 10:10PM
..oh. I was just planning the exact same thing...
What exactly makes this so improbable? Is it rigidity?
September 07, 2015 03:37AM
improbable????
i just think they are nuts, who will need a build area that big?
but yes it will have to be rigid or it will shake itself apart or just make bad prints
September 07, 2015 07:58AM
4 words:
Life size Yoda heads! hot smiley
You don't have to wait for someone to post a life-size model on Thingiverse- just use the scale function in your slicing software. If you have a large format printer you can print it.
September 07, 2015 08:01AM
looool
of course....
btw have read the instructable for the megamax and its follower... very interested in copy'ing that off :-D
September 07, 2015 08:31AM
Something else to consider: Electronics.
A bigger delta means you will at least triple the mass of the arms. This will require stronger steppers and probably will result in currents higher than your standard arduino printer electronics drivers can handle. I would also be leary of any material for delta arms at that length. Almost anything other than chromed linear rods will start flexing.
A H-bot or CoreXY will require the gantries to use larger diameter rods, but thats about all. You should not need larger steppers. The Z table will be much bigger, but since it moves so slow you can get away using a gearbox on that stepper without increasing current.
Of course you can always use CNC stepper controllers. Personally, I would prefer to tackle one thing at a time. In this case, tackle the stability issues you face and not worry about non-standard electronics, firmwares, and software problems for another project.
Oh, another thing: Heated bed. Your best bet is to use AC voltage heating bars and drive them with an SSR. You will not be able to find a DC heater big enough (unless you power the heater from a separate PSU).
"Never argue with stupid people, they will drag you down to their level and then beat you with experience."
September 07, 2015 09:29AM
Hazer
No way should you use metal rods to connect the effector of a delta. Use carbon fibre tube. 6mm tube is stiff enough for the 350mm arms of my delta, and stiffness varies with the cube of the diameter AFAIR. I think 10mm tube should be plenty stiff enough if you decide to go the delta route. You can stick with Nema 17 stepper motors. You will need a very stiff frame, but that goes for any large printer.
Hazer
I agree. My delta uses a mains powered heated bed.
September 07, 2015 09:34AM
heat bed.. yeah the other hackers said "we just chain up 9 mk2 beds"
i laughed and asked them how much current that would be
they thought at it for 1 min and came up with a approx 80A number and i told them to say 15A * 9 and asked where they would get a 12V psu rated that much at an fair price
before they could answer i added the bonus Q: why not use a 230V silicone heater and a SSR with zero point detection build in..... they humble accepted defeat :-D
But yes i i'm more and more convinced about a H bot... delta could be done... but the arms yes... it will be problematic to say it mild
let's see, we only meet weekly so it will not be until the end of week i know what they decide on
September 08, 2015 02:27AM
boelle
Maybe they meant to put them in series and feed 110V~ (US-) mains to them? Has anyone done that before? ( and survived ? ) sad smiley
I like the idea of using multiple heatbeds. It saves energy, when you print small parts.
But to be consequent, the heatspreader should be split too, which is a nightmare to level.
-Olaf
PS: I´m currently thinking about an " 4 SCARA arms printer " I have a "SCARA"-design in mind which only requires linear/polar math. ( the design is not shown in this pic, it´s an early napkin sketch )
September 09, 2015 04:18PM
I wish you the best on your endeavor.
I exhibited my printer (which was built at our makerspace called Vocademy in Riverside CA) in the booth next to SeeMeCNC at the World 3D Printer Expo in Burbank, so I got to see their big delta working over a couple days.
Unfortunately, that printer is good for only one thing - getting press (and yes the local news did come to film it).
There was no retraction so there was a lot of stringing.
The pellet feeder makes the effector so heavy that the entire machine flexes with every move.
Eventually the nozzle would hit the print and knock it, and it would be off - making biggest spaghetti you've ever seen, and not one good print the entire weekend.
So what I took away from that is - if you are going to build a big delta, then make it very rigid indeed, and the effector must be just as light as you can make it.
My printer: Raptosaur - Large Format Delta - [www.paulwanamaker.wordpress.com]
Can you answer questions about Calibration, Printing issues, Mechanics? Write it up and improve the Wiki!
September 09, 2015 04:26PM
mains whatever its 230 or 115 does not matter much....
what is important is the isolation between tracks on the PCB... next how "accessible" the tracks are to fingers, of course the solder terminals are the worst spot...
but i bet the isolation distance between the tracks are so poor you risk jumps from one track to the other and hence maybe the resistance gets so low it will blow a fuse....
i would not worrie about getting shocked.... mains is not dangerous at all... its the lack of respect for mains that kills :-D
money wise i bet 9 pcb's cost more than a custom silicone heater from china.... so it would not make much sence anyway :-D
September 09, 2015 04:35PM
if i have a say in the project i think i would vote for an H bot.... seems more and more like the most logic / commonsence choice here
@the_digital_dentist - you think the SoM at the 600*600 bed size would cut it?
September 09, 2015 06:17PM
I wouldn't try to do that. I wouldn't try to go any bigger than it already is. Too much moving mass in the Y axis. If i were building a cartesian machine that had a 600 x 600 bed, I'd probably look at CoreXY or similar design with the bed only moving in the Z axis.
September 09, 2015 07:04PM
boelle
you can get 12v 100amp psu's for around 30 dollars on amazon... (not saying that the idea is practicable, but that they arent crazy expensive) look up a Server power supply
Edited 1 time(s). Last edit at 09/09/2015 07:05PM by Qdeathstar.
