DC42 Web Interface duet ip config.g November 24, 2015 11:50AM |
Re: DC42 Web Interface duet ip config.g November 24, 2015 12:37PM |
Re: DC42 Web Interface duet ip config.g November 24, 2015 01:51PM |
Re: DC42 Web Interface duet ip config.g November 25, 2015 06:38AM |
Re: DC42 Web Interface duet ip config.g November 25, 2015 07:38AM |
Re: DC42 Web Interface duet ip config.g November 25, 2015 09:19AM |
Re: DC42 Web Interface duet ip config.g December 03, 2015 05:54AM |
Re: DC42 Web Interface duet ip config.g December 03, 2015 08:00AM |
M550 PPrinterName ; Machine name and Netbios name (can be anything you like) M551 Preprap ; Machine password (used for FTP) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address ;*** Adjust the IP address and gateway in the following 2 lines to suit your network M552 P192.168.1.10 ; IP address (0 = use DHCP) M554 P192.168.1.1 ; Gateway M553 P255.255.255.0 ; Netmask
Re: DC42 Web Interface duet ip config.g December 04, 2015 08:54AM |
M550 PPrinterName ; Name has been changed... PNewName M551 Preprap ; Password is the same M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address has been changed and verified by IS M552 P142.168.1.10 ; IP address has been assigned and Assigned by IS M554 P142.168.1.1 ; Gateway --- I took the gateway from my laptop by using IPCONFIG /all M553 P255.255.255.0 ; Netmask I got this from my laptop by using IPCONFIG/all
142.168.1.18 ; IP address 142.168.1.1 ; Gateway 255.255.255.0 ; Netmask
M552 P0 ; IP address (0 = use DHCP) M554 P0 ; Gateway M553 P0 ; Netmask
Re: DC42 Web Interface duet ip config.g December 04, 2015 09:44AM |
Re: DC42 Web Interface duet ip config.g December 15, 2015 09:21AM |
>>> M554 P0.0.0.0 SENDING:M554 P0.0.0.0 >>> M553 P0.0.0.0 SENDING:M553 P0.0.0.0 >>> M552 P0.0.0.0 SENDING:M552 P0.0.0.0 >>> M552 SENDING:M552 Network is enabled, configured IP address: 0.0.0.0, actual IP address: 142.168.1.10, HTTP port: 80 >>> M553 SENDING:M553 Net mask: 0.0.0.0 ok >>> M554 SENDING:M554 Gateway: 0.0.0.0 ok
SENDING:M502 >>> M553 SENDING:M553 Net mask: 255.255.255.0 ok >>> M552 SENDING:M552 Network is enabled, configured IP address: 192.168.1.10, actual IP address: 142.168.1.10, HTTP port: 80
Re: DC42 Web Interface duet ip config.g December 15, 2015 09:30AM |
