I have an i3 Prusa that i just finished building and I think the power supply is crap. It only outputs 10.75 Volts and that's after i tried to adjust it with the set screw. When I attempted to do a test print the extruder couldn't heat above 167, it would bounce around 165.5 to 167.0 while the target temperature was set to 200.
just checked the voltage to the print head, its only 8.5 V
Any ideas?
Edited 1 time(s). Last edit at 01/20/2016 11:30PM by DaGameFace.
