What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 06, 2016 07:13AM |
Re: What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 06, 2016 08:35AM |
Re: What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 06, 2016 11:33AM |
Re: What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 06, 2016 09:22PM |
Re: What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 06, 2016 11:08PM |
Re: What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 07, 2016 01:09AM |
Re: What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 07, 2016 05:34AM |
Re: What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 07, 2016 12:11PM |
leadinglights
One problem with using designs from the CNC world is that there may be a number of swaps between heads on a single layer and these may need to be rapid. An example is in laying down support material where a layer may involve two heads for perhaps the larger part of the print. Mixed materials like building flexible hinge material into a rigid part are another example - adding a different colour and there could be four heads being swapped between for each layer.
A good method may be like Srek's design with two X carriages, but with swap-out mechanisms on one or both ends so that while one head is printing another may be swapped out.
The simple swaping of entire heads is no mean task though, remember that it may involve not just a heater element and temperature sensor, but also some method of cooling the non-printing end of the nozzle, perhaps some directed air flow to cool the print and of course, wires for the extruder or a bowden tube.
A mechanism for a multi headed design could be beguilingly simple, but the sorts of problems that it introduces soon get to be endless. Hopefully the inner glow from getting it all working will be satisfaction enough.
Mike
Re: What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 07, 2016 01:03PM |
Re: What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 07, 2016 01:36PM |
Re: What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 07, 2016 02:27PM |
leadinglights
Just to pick up on one point - there are too many to address everything.
If colour is the object in having more than one head then an external machine that cuts lengths of filament and welds them would be a good start. However, I am not too artistic and multicoloured Yodas are only of passing interest. When it comes to multiple material printers however, you would have my full attention. Consider a prosthetic hand - if this is to be printed in one piece there would need to be rigid materials for the bones, flexible materials for the joints, a different flexible material with a high tensile strength for the tendons along with a dissoluble support material so that parts could have a more natural form. Four materials there alone - a fifth to cover anything I had not thought of would seem to be a minimum.
With sufficient inventiveness a great deal can be accomplished - even the suggestion that a simple 3D printer could be made by a private individual within a hobby budget was unthinkable to most a few years ago. Having said that, even a 5 head 3D printer is terrifying enough for me.
Mike
Re: What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 07, 2016 04:21PM |
realthor
What I see is that many high-end (?) machines use this type of tool exchanger: https://www.youtube.com/watch?v=ZyyqOfUsvnY&feature=youtu.be&t=36. I have no idea what it involves, if the sounds mean pressured air escaping (and involved in the swap) ...
Re: What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 07, 2016 05:59PM |
Koko76
realthor
Each tool has a retention knob, which is gripped by hardened steel "fingers". They open and close via a sliding rod held in place with a stack of bellville washers, with a combined force of around 3000lbs on a 40 taper machine like shown. The stack is compressed with either an air/hydraulic or a hybrid system, only with the spindle stopped. When uncompressed it pulls the tool up into the taper, both locating and providing a significant portion of the friction needed to transfer power into the tool The exchange arm moves up and down and rotates typically via a complex cam gearbox that coordinates both functions but only uses one motor. There are spring loaded fingers which grip and release the tool in the arm that are locked as the arm is lowered prior to rotation. When this mechanism sticks, the machines tend to throw tools. Makes life interesting. Typical tool to tool is on the order of a few seconds, and with a random access side mount chip to chip is generally 5-10 seconds at worst at full rapids, assuming you can pre-index the next pocket. Construction of such a system further involves a number of sensor inputs to determine what part is in what position at what time, what tool pocket is where when you start from power off, and what tool has been placed in what pocket (when operated in random access mode). Compressed air is typical used to open and close the drawbar, as well as to blow off the taper during tool exchange as chips go everywhere and are problematic when they get between the tool and spindle. When you use oil lubricated spindle bearings you also typically blow air with an oil drip through the bearing to keep positive pressure coming out of the bearing and the labyrinth seal at the bottom to prevent coolant ingress into the spindle bearings.
Re: What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 08, 2016 07:05AM |
Re: What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 08, 2016 02:30PM |
Admin Registered: 13 years ago Posts: 730 |
Re: What would be a good mechanism for automatically swapping working heads for Cartesian 3d printers? February 08, 2016 05:02PM |
MattMoses
These videos show a tool changer on an Ultimaker that appears to work quite well:
If you haven't found these old threads already, they show some design ideas that may be helpful:
