extract configuration.h February 10, 2016 11:41AM |
Re: extract configuration.h February 10, 2016 11:59AM |
Admin Registered: 16 years ago Posts: 13,902 |
Re: extract configuration.h February 10, 2016 12:37PM |
Re: extract configuration.h February 10, 2016 01:55PM |
Re: extract configuration.h February 10, 2016 03:31PM |
Re: extract configuration.h February 12, 2016 08:12AM |
Re: extract configuration.h February 12, 2016 09:43AM |
Re: extract configuration.h February 14, 2016 10:31AM |
bizit524
@VDX - This is what I was afraid of not being able to extract it.
@hoxsiew -I will however its not like they are refusing to give it to me, the literally just dont respond. In a sense it is refusing they did that with the STL files I asked for, for the original 3d printed parts. Really annoying
@eried - I have the aluminum version as well! could you send them to me? Yeah I saw the steps per mm currently everytime I turn it on I just reset it to what I have calibrated it. very annoying but I have been waiting till I get a hold of the original file before I start messing with it.
Also speaking of the steps per MM. they sold to me a 200x270 bed which is fine, works great HOWEVER i actually measured the bed and its 220x270. This is great extra 20 mm! just tried printing on that side and it literally doesn't print on it even if I set the settings in slic3r or cura. The nozzel/ x carriage has enough room to move all the way to the end of the rail without hitting anything. I suspect that is another firmware limitation that I have to change. Where would I go about changing that. once I have the configuration.h file?
Re: extract configuration.h February 16, 2016 08:28AM |
eried
bizit524
Well my file is already modified with leadscrews and autolevelling [www.thingiverse.com] not sure if is useful for you. And you need to adjust the bed limits in the configuration.h and cura aplication itself to reach all the corners of the bed
Re: extract configuration.h February 16, 2016 09:32AM |
Re: extract configuration.h February 17, 2016 07:29AM |
Thanks so much this will help greatly. That is good you have modified those, I have noticed that as well along with I wanted to change one setting that is moving all the axis and the extruder instead of in the prepare menu which makes no sense I wanted to put it into the other menu below itQuote
eried
Sure, here are all the files I modified: [cloudup.com]
Download the latest marlin firmware and replace those. I modified some other parts to improve the user experience of the hictop printer, for example the encoding wheel was very imprecise and when I pushed it sometimes was choosing another option, etc
Re: extract configuration.h February 17, 2016 10:57AM |
Re: extract configuration.h February 24, 2016 05:51PM |
Re: extract configuration.h February 24, 2016 08:52PM |
bizit524
sorry for the extremely late response! ha didn't know that was you. i have already found most of your designs on thingiverse and have printed some. I just actually finished printing your z axis hictop version for threaded screws when mine come in, However I have not found that anybody has designed a z axis part which includes threaded portion on z AND X. I have found either or but not both. Have you located any of these by chance? I try to search Everything but the search function is HORRENDOUS. It searches all tag lines, entire body, and title i believe which makes it very inefficient
Thank you VDX i have now taken eried and edited it to the bed
I have also a question/s. Do you happen to remember the steps per mm for the threaded rod? I tried looking mine up but I cant find it anywhere. I found this on the metric standards but doesn't indicate if mine fits this
"A typical M8 rod has a pitch of 1.25"
I have changed the acceleration to 1500 instead of 3000 in line 3,4 and 6 because I was getting ringing. Is this ok or do I have to change it elsewhere?
I BELIEVE the first line is where i change the x axis steps per mm? it would be the 400?
It also looks like you have enabled the saving of EEPROM settings is this true? because I was looking for this as well but from googling it looks already setup.
Lastly I just changed the location of the y endstop sensor from under the bed to against my stepper motor. This is great however since it has changed i believe my bed is off by about 14 mm. IF I calculated right. Where is the offset setting for the y axis endstop? I see multiple y offset settings but not sure which one correlates with the endstop
What is the config_adv that you included? do i put this in as well when uploading?
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,400,98.5}
#define DEFAULT_MAX_FEEDRATE {300, 300, 5, 45} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {1500,1500,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 1500 // X, Y, Z and E acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration in mm/s^2 for retracts
#define DEFAULT_TRAVEL_ACCELERATION 1500 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves
// The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously)
#define DEFAULT_XYJERK 20.0 // (mm/sec)
#define DEFAULT_ZJERK 0.4 // (mm/sec)
#define DEFAULT_EJERK 5.0 // (mm/sec)
Re: extract configuration.h April 24, 2016 11:39AM |
// Default AXIS STEPS, MAX_FEEDRATE, ACCLERATION settings // Default AXIS STEP Settings (motor steps) X, Y, Z, E // 1a) default axis steps per unit for Ultimaker steps/mm ={8.7402,78.7402,200.0*8/3,760*1.1} // 1b) default axis steps per unit for HIC i3 steps/mm ={80,80,2560,94.4962144}, OEM z-axis threaded rods =8mm wide x 1.25mm pitch //#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,2560,94.4962144} // original default for HIC i3, (steps/mm) #define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,2559,98.6} // CL: default steps for _my_ HIC i3, you may need to change the Z and/or E for your machine // Default MAXIMUM FEEDRATES (motor speeds) X, Y, Z, E - GLOBAL for printing and non-printing //#define DEFAULT_MAX_FEEDRATE {200,200,5,17} // (mm/sec) default for Makerbot i3 //#define DEFAULT_MAX_FEEDRATE {500,500,5,25} // (mm/sec) default for HIC i3 #define DEFAULT_MAX_FEEDRATE {120,120,3,25} // (mm/sec) CL: default for _my_ HIC i3 max feedrate rated at ~120mm/sec // Default MAXIMUM ACCELERATION (motor) X, Y, Z, E=(extrusion only) - max start speeds for accelerated moves // NOTE: value stored in DEFAULT_ACCELERATION if lower, will limit these MAX rates //#define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000} // (mm/sec^2) default for HIC i3 - X, Y, Z, E(moves) maximum start speed for accelerated moves #define DEFAULT_MAX_ACCELERATION {1200,1200,50,10000} // (mm/sec^2) CL: for _my_ HIC i3 - X, Y, Z, E(moves) maximum start speed for accelerated moves // E default values are good for Skeinforge 40+, for older versions raise them a lot. // Default misc. ACCELERATIONS //#define DEFAULT_ACCELERATION 500 // (mm/sec^2) default for Makerbot i3 - X, Y, Z and E max acceleration for printing moves //#define DEFAULT_ACCELERATION 3000 // (mm/sec^2) default for HIC i3 - X, Y, Z and E max acceleration for printing moves #define DEFAULT_ACCELERATION 1200 // (mm/sec^2 ) CL: for _my_ HIC i3 - X, Y, Z and E max acceleration for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // (mm/sec^2) E acceleration for retracts (fliament purge and feed) #define DEFAULT_TRAVEL_ACCELERATION 1200 // (mm/sec^2) X, Y, Z acceleration for travel (non-printing) moves // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) // default jerk values for HIC i3 ={20.0, 0.4, 5.0} (mm/sec) #define DEFAULT_XYJERK 2.0 // CL: For HIC i3, was =20, (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec)
Re: extract configuration.h May 25, 2016 10:17PM |
Re: extract configuration.h May 25, 2016 10:44PM |
Admin Registered: 13 years ago Posts: 7,008 |
