SmoothieBoard Users March 02, 2016 03:36PM |
Re: SmoothieBoard Users March 02, 2016 04:51PM |
Re: SmoothieBoard Users March 02, 2016 09:19PM |
Re: SmoothieBoard Users March 03, 2016 02:55AM |
Re: SmoothieBoard Users March 03, 2016 06:05AM |
Re: SmoothieBoard Users March 03, 2016 08:23AM |
Re: SmoothieBoard Users March 03, 2016 08:57AM |
Re: SmoothieBoard Users March 03, 2016 09:08AM |
Bundybear1981
Mostly I'm trying to find how users that currently have a SmoothieBoard find it to use and if they wish in hindsight they selected a different board as these boards are not on the cheap side so I would rather buy once and get a reliable and suitable board.
the_digital_dentist
What will you be using networking for? Smoothie has it, but to me it seems sort of pointless.
Re: SmoothieBoard Users March 03, 2016 10:47AM |
Koko76
File upload without removing the sd card and resetting the machine. Web interface better than pronterface and works over Ethernet.
ElmoC
I bought a Smoothie and find I should have saved my money. While the hardware is nice, like Koko76 said, the software is not as nice as other solutions. The one big thing about the software that surprised me was the lack of soft end stops that even Marlin has. This cost me a glass plate when I accidentally moved the Z axis in the wrong direction. Smoothie happily tried moving the hot end 20mm through the bed, shattering the plate and bending the heater.
ElmoC
The network on the Smoothie is pretty pointless it seems. Not so with the Duet. Or even if you add an Octoprint server to a board without a network connection. While as you mentioned, all the maintenance and prep, the networking can provide help. You don't have tiny SD cards to lose. You can queue up more prints while a print it running. It allows remote monitoring and can allow for notifications when prints are done or there is a problem. It frees the computer from the printer during a print job. It can provide better feedback as to the progress of the print.
The description you gave about the workflow of the CubePro sound more like an issue with the printer, not the network.
Re: SmoothieBoard Users March 03, 2016 10:54AM |
Re: SmoothieBoard Users March 03, 2016 03:33PM |
the_digital_dentist
What will you be using networking for? Smoothie has it, but to me it seems sort of pointless. A 3D printer requires that you change or verify adequate filament, prep the bed (clean, level, zero, etc.), and remove the last print manually. Since you have to be at the machine to do those things, what's the point of networking the machine? While you're at the machine doing those things, why not just plug in an SD card and start the print?
Re: SmoothieBoard Users March 03, 2016 05:33PM |
Admin Registered: 16 years ago Posts: 13,909 |
Re: SmoothieBoard Users March 03, 2016 06:57PM |
the_digital_dentist
How does networking help change filament, prep the bed, or remove the last print?
the_digital_dentist
What value is queuing more prints while a print is running if you have to go to the machine to remove the last print before then next one can start (and maybe change the filament spool)?
the_digital_dentist
Remote monitoring can be accomplished with a cheap web cam.
the_digital_dentist
An LCD panel with SD card reader and encoder frees the machine from the computer. Octoprint/Octopi is just another host computer using the USB interface to the printer.
the_digital_dentist
Monitoring print progress? Hmmm. The slicer gave me an estimate of the time it would take to print. My watch is all I need to monitor print progress and completion.
the_digital_dentist
The workflow issue with the CubePro isn't a printer problem, it's a pointless networking problem. If it weren't networked, there'd be no back and forth running around. Any printer with networking that doesn't automatically change filament, remove the last print, or prep the bed surface for the next print, is going to require similar operating procedures. How could it not?
Re: SmoothieBoard Users March 03, 2016 10:44PM |
Koko76
I'm not advocating pronterface, what I'm advocating is different and better. Perhaps if you had experience with what you are talking about you might have a different opinion. I bought and used both boards. Have you, or are you just speculating?
Re: SmoothieBoard Users March 03, 2016 11:05PM |
the_digital_dentist
ElmoC, removing the last print, changing or weighing filament remaining, prepping the bed are all things you can't do via a network and are all things that must be done before every print. This IS the whole point of the networking discussion.
Just as anyone who have had an SD card fail when printing has seen. There are lots of points of failure in this whole printing process. Just because you use an SD card doesn't mean you have eliminated all of them or that you have more reliability. Network communication using a wired TCP/IP connection is extremely reliable. A properly configured USB connection is also reliable. Most of the problems I see with a USB connection is from poor cables or poor USB implementation on the printer end.Quote
the_digital_dentist
Anyone who has ever had a print fail because of a USB comms problem or a computer problem has seen it demonstrated.
Re: SmoothieBoard Users March 04, 2016 07:44AM |
Re: SmoothieBoard Users March 04, 2016 08:17AM |
Re: SmoothieBoard Users March 04, 2016 09:50AM |
Re: SmoothieBoard Users March 04, 2016 03:37PM |
Re: SmoothieBoard Users March 04, 2016 03:38PM |
Re: SmoothieBoard Users March 04, 2016 04:16PM |
$ cat .xchat2/xchatlogs/FreeNode-\#reprap.log | grep -i rambo | wc -l 5325 $ cat .xchat2/xchatlogs/FreeNode-\#reprap.log | grep -i ramps | wc -l 43886 $ cat .xchat2/xchatlogs/FreeNode-\#reprap.log | grep -i smoothie | wc -l 14818 $ cat .xchat2/xchatlogs/FreeNode-\#reprap.log | grep -i melzi | wc -l 1919 $ cat .xchat2/xchatlogs/FreeNode-\#reprap.log | grep -i duet | wc -l 474 $ cat .xchat2/xchatlogs/FreeNode-\#reprap.log | grep -i gen6 | wc -l 3006 $ cat .xchat2/xchatlogs/FreeNode-\#reprap.log | grep -i printrbot | wc -l 7709
$ tail -n 1000000 .xchat2/xchatlogs/FreeNode-\#reprap.log | grep -i ramps | wc -l 4210 $ tail -n 1000000 .xchat2/xchatlogs/FreeNode-\#reprap.log | grep -i smoothie | wc -l 3144
Re: SmoothieBoard Users March 04, 2016 07:03PM |
Re: SmoothieBoard Users March 05, 2016 04:51AM |
Re: SmoothieBoard Users March 05, 2016 08:19AM |
Koko76
