Re: Piezoelectric disks for Z contact detect and bed levelling March 17, 2017 09:10AM |
DjDemonD
Yes I have been commenting about polarity a lot as it seems to now make sense based on what you've said to be quite random. I presumed it was because I was using the inverted logic instead, one way around they seem to trigger but the voltage rise (maybe Mike you've seen this on your scope?) is not fast enough to trigger quickly enough and you get a crash, the other way around they are amazingly precise.
So something to be wary of with our experimental beta units, if its performing poorly, reverse the piezo connector. For pre-built units I will make sure they are the right way round, by testing them on the rig, before they go out of the door.
Re: Piezoelectric disks for Z contact detect and bed levelling March 17, 2017 09:26AM |
Re: Piezoelectric disks for Z contact detect and bed levelling March 17, 2017 09:43AM |
Re: Piezoelectric disks for Z contact detect and bed levelling March 17, 2017 11:05AM |
Re: Piezoelectric disks for Z contact detect and bed levelling March 17, 2017 11:43AM |
Re: Piezoelectric disks for Z contact detect and bed levelling March 17, 2017 11:56AM |
DjDemonD
Okay so the idea is one part of the disc is attached to the hotend the other to the mount?
Re: Piezoelectric disks for Z contact detect and bed levelling March 17, 2017 12:06PM |
Re: Piezoelectric disks for Z contact detect and bed levelling March 17, 2017 12:13PM |
Re: Piezoelectric disks for Z contact detect and bed levelling March 17, 2017 01:53PM |
DjDemonD
Is there an easy, no oscilloscope needed method of determining the correct polarity before installation as it doesn't seem obvious just watching the led on the piezo board?
Re: Piezoelectric disks for Z contact detect and bed levelling March 19, 2017 08:21PM |
JamesK
For my intended use case of three point under bed mounts I wanted to be able to cope with the bed moving in opposite directions at the sensors for some probing points, so my circuit rectifies the signal before passing it to the op-amp, and uses three separate channels with the output combined digitally at the comparator output. It's not particularly expensive using quad op-amp, quad comparators.
Re: Piezoelectric disks for Z contact detect and bed levelling March 19, 2017 08:41PM |
Quazzer
Could you share your schematic withus please. In particular how do you rectify the signal? Thanks
Re: Piezoelectric disks for Z contact detect and bed levelling March 20, 2017 07:06AM |
JamesK
Sorry, I don't have a schematic done up. Rectification was just the typical diamond arrangement using four discrete diodes. One side of the resulting output is tied to ground, the other goes to the op-amp. I'm using the LM324 which copes with running on a single supply and is cheap on ebay. The output is fed to a LM339 quad comparator which tests the output against an adjustable reference voltage (generated with a cermet and buffered by the spare 4th op-amp on the LM324).
I should 'fess up that I only tested a single channel and not on a printer, so the benefits (or even the feasibility) of the circuit are unproven.
Re: Piezoelectric disks for Z contact detect and bed levelling March 20, 2017 07:12AM |
Re: Piezoelectric disks for Z contact detect and bed levelling March 23, 2017 06:51AM |
Re: Piezoelectric disks for Z contact detect and bed levelling March 23, 2017 06:55AM |
Re: Piezoelectric disks for Z contact detect and bed levelling March 23, 2017 07:01AM |
DjDemonD
Looks very familiar. Be interested to hear if they have refined it, and how? Lets hope its not a closed source project that would be a shame.
It might be worth also highlighting this module [www.thingiverse.com] which seems to pre-date our efforts, or perhaps arose around the same time.
Re: Piezoelectric disks for Z contact detect and bed levelling March 23, 2017 11:50AM |
Re: Piezoelectric disks for Z contact detect and bed levelling March 23, 2017 12:42PM |
Re: Piezoelectric disks for Z contact detect and bed levelling March 23, 2017 12:59PM |
Re: Piezoelectric disks for Z contact detect and bed levelling March 24, 2017 07:41AM |
Unfortunately, I ran out of spare time before I could test it. Hopefully next week...|
Re: Piezoelectric disks for Z contact detect and bed levelling March 25, 2017 07:06AM |
Re: Piezoelectric disks for Z contact detect and bed levelling March 25, 2017 07:19AM |
Re: Piezoelectric disks for Z contact detect and bed levelling March 25, 2017 08:20AM |
Re: Piezoelectric disks for Z contact detect and bed levelling March 31, 2017 06:53AM |
frankvdh
I'm not pro/anti Piezo... in fact I hadn't heard of them until a couple of weeks ago. Just trying to see what is practically available.
leadinglights
[*] Claim: Piezos become insensitive at higher temperatures
Truth: This varies with the make but all that have been tried are satisfactory up to at least 60°C\
But surely that kills their usefulness right there? For PLA, I have my glass bed heated to 70C, and for ABS 100C. How satisfactory are Piezos at those temperatures?
Re: Piezoelectric disks for Z contact detect and bed levelling March 31, 2017 08:49PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 01, 2017 01:58AM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 01, 2017 03:29AM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 01, 2017 04:13AM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 02, 2017 09:31AM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 03, 2017 07:23AM |
