Servo motor driver Polulu drop-in replacement March 06, 2016 04:06PM |
Re: Servo motor driver Polulu drop-in replacement March 07, 2016 04:58PM |
Re: Servo motor driver Polulu drop-in replacement March 07, 2016 05:32PM |
MechaBits
I've been thinking about a dual shaft 0.9deg nema coupled to one of these
[www.ebay.co.uk]
and wired into something to make it all work...is this what your driver could do?
Re: Servo motor driver Polulu drop-in replacement March 07, 2016 06:31PM |
Re: Servo motor driver Polulu drop-in replacement March 07, 2016 06:41PM |
Re: Servo motor driver Polulu drop-in replacement March 07, 2016 07:28PM |
the_digital_dentist
Do steppers lose steps when operated within their specs?
Re: Servo motor driver Polulu drop-in replacement March 07, 2016 09:45PM |
Re: Servo motor driver Polulu drop-in replacement March 07, 2016 10:39PM |
That's the nice thing about servos, you know where it is, you know where you want it to be and it's always trying to close the gap between the two. If you take it out of spec temporarily, perhaps by hitting a curled up edge, it can recover once the over-spec situation passes.Quote
how can you be sure of operating servos within their specs?
It would be very impressive to get a driver into the same form factor as the standard stepper modules. Is that the intention, or are you planning a larger board with a connector to plug into the socket?Quote
that would be a drop-in replacement for the standard Polulu stepper drivers
Re: Servo motor driver Polulu drop-in replacement March 08, 2016 12:34AM |
JamesK
Re: Servo motor driver Polulu drop-in replacement March 08, 2016 12:53AM |
the_digital_dentist
If they aren't losing steps, they're probably operating within spec, and if they are, they aren't.
If you can't be sure of operating steppers within their specs, how can you be sure of operating servos within their specs?
Re: Servo motor driver Polulu drop-in replacement March 08, 2016 01:58AM |
Admin Registered: 13 years ago Posts: 730 |
I think this is a great idea! It is something I've wanted to work on for some time, but never got around to it. There was a discussion about this very same idea in this thread from two years ago.Quote
LoboCNC
I'm thinking about designing a servo motor controller/driver that would be a drop-in replacement for the standard Polulu stepper drivers.
Re: Servo motor driver Polulu drop-in replacement March 08, 2016 12:11PM |
Re: Servo motor driver Polulu drop-in replacement March 09, 2016 08:07AM |
Re: Servo motor driver Polulu drop-in replacement March 09, 2016 08:38AM |
Re: Servo motor driver Polulu drop-in replacement March 09, 2016 11:41AM |
Re: Servo motor driver Polulu drop-in replacement March 09, 2016 12:22PM |
Re: Servo motor driver Polulu drop-in replacement March 09, 2016 01:47PM |
owenlab
Hi LoboCNC, I'm working on the same project, using an MCU and a motor driver all in a single board that is possible to put in to the pololu socket.
You are working on a linear enconder in the axis or a motor enconder?
Re: Servo motor driver Polulu drop-in replacement March 21, 2016 01:09PM |
Re: Servo motor driver Polulu drop-in replacement March 21, 2016 03:30PM |
jonnycowboy
What about instead of Polulu replacements you use something like Dynamixel AX-12 or MX-12 servos? Then you save the 20$ controller (though the motor itself is more expensive). You also gain temperature and load feedback. Resolution can be pretty good depending on if you use the AX-12A (slow but accurate) or AX-12W or MX-12W (faster but less accurate).
Re: Servo motor driver Polulu drop-in replacement March 21, 2016 04:04PM |
jonnycowboy
