Large Scale Nozzle April 27, 2016 10:28PM |
Re: Large Scale Nozzle April 28, 2016 01:05AM |
Re: Large Scale Nozzle April 28, 2016 02:09AM |
Re: Large Scale Nozzle April 28, 2016 02:43AM |
mdashd
At the moment, the motor is pushing hard into the hot end which is producing a lot of back pressure in the filament. The limiting factor seems to be the nozzle. I’ve read that speed is proportional to hot-end temperature (hence the high thermal mass of the nozzle), but is there anyway that the nozzle might be physically altered to increase the speed of the extrusion?
Does anyone have any suggestions for ways I might be able to modify the nozzle (or the setup as a whole) in order to reduce the back pressure and increase the speed of the extrusion?
Thanks kindly for your help
Re: Large Scale Nozzle April 28, 2016 03:08AM |
Re: Large Scale Nozzle April 28, 2016 03:25AM |
mdashd
Do you have any ideas of what might happen if I shifted your changes a little and put the narrowest part higher within the nozzle?
Would it change the diameter of the resulting extrusion? As it reduces the volume of the melt chamber, would it also reduce the volume of the throughput also? Or would the bottom end also be considered part of the melt chamber?
Re: Large Scale Nozzle April 28, 2016 06:09AM |
Re: Large Scale Nozzle April 28, 2016 11:39AM |
Re: Large Scale Nozzle April 28, 2016 08:56PM |
Srek
A long or voluminous melt zone is something that can be helpful for extrusion at continuous speed, but you only have that with injection molding or very few special cases in FDM. In general the extrusion needs start and stop very often and is done at various speeds in one print.
Srek
I have to disagree with Paul on the pointiness of the Nozzle. For the Merlin i use airbrush nozzles, they are nearly needle thin and you get perfect layer bonding. An "ironing" nozzle will pose problems when it comes to bridging, something a pointy nozzle does very well.
Srek
Your latest change, will not have any advantage, my guess is that extrusion will just become less precise than it could be.
If you fear that the filament is not melting fast enough you could use one of two tricks
1. put a brass pin horizontally through the melting zone. This will increase backpressure a bit, but will also ensure that the filament is completely molten.
2. put the outlet at about 90° to the inlet
I tried option 1 myself but did not pursue since it just wasn't necessary in the end.
Option 2 is a bit more difficult to machine, but should work with less pressure
Re: Large Scale Nozzle April 29, 2016 02:09AM |
Re: Large Scale Nozzle April 29, 2016 07:42AM |
Re: Large Scale Nozzle April 29, 2016 12:59PM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: Large Scale Nozzle May 01, 2016 01:46AM |
Re: Large Scale Nozzle May 01, 2016 03:43AM |
Re: Large Scale Nozzle May 01, 2016 04:22AM |
Srek
Molten plastic is not as incompressible as water.
Re: Large Scale Nozzle May 01, 2016 05:59AM |
