oxygen barriers for sla 3d printers
May 17, 2016 01:00AM
Hi, I was wondering why know one has used salt water as an oxygen permeable membrane on a sla 3d printer. The peachy printer proved it sinks in resin and water absorbs oxygen. Additionally using water on would allow you to do this on and sla 3d printer. Thanks for your input/opinion.spinning smiley sticking its tongue out
VDX
Re: oxygen barriers for sla 3d printers
May 17, 2016 03:25AM
... with salt-water you don't need oxygene, as its only used to prevent curing of the resind while in contact with the bottom surface.
The only "drawback" with a fluid membrane is the inconsistent surface while pulling the object up, so the inner areas of voluminous parts won't be precise leveled, but slightly koncave, until the resin from the outside will refill the cavities again ...
Viktor
May 17, 2016 08:35AM
For a bottom up SLA, salt water will distort the image projected by the projector or laser.
VDX
May 17, 2016 10:36AM
ggherbaz
... this is only a scaling offset, so no real problem, if the height of the salt-water volume didn't change while printing ...
Viktor
May 17, 2016 06:13PM
What if you used an oil with a low surface tension?
VDX
May 17, 2016 06:26PM
... you'll need a "phobic" fluid, which won't mix with the resin, and best one with higher density, so it will stay under the resin in the bottom-up approach ...
Viktor
May 17, 2016 06:36PM
You could use this on your build plate and water
Edited 1 time(s). Last edit at 05/17/2016 06:38PM by robotseth.
