Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 11:41AM |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 11:58AM |
Admin Registered: 16 years ago Posts: 13,910 |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 11:59AM |
VDX
... how thick?
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 12:16PM |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 12:59PM |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 01:05PM |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 01:10PM |
amigob
i uses boro glass and 1.5 mm head spreader with silicon heater. it works very well.
But be care full aluminum will expand 2 times of the boro glass.
I used 10x10cm squares and used dubble side tape to stick these squares to the glass with 1mm spacing
This is to avoid deformation of the glass when the alluminium is expanding more then the boro glass
No fir image but measured heat map
and on aly express you can get the dubble side tape sheets for a good price
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 01:14PM |
realthor
The glass will not float on the aluminum but the aluminum will be glued underneath the glass and the silicone heater will be glued to the aluminum. The glass will be directly supported on the bed frame 3-point-screws so if aluminum warps (and i hope the adhesive will keep it stuck to the glass) it will not affect the glass' position.
Now I wonder where can I find some double adhesive tape that is heat conductive and resistand to the temps of a heated bed while being thin enough to efficiently transfer the heat from the aluminum to the glass....
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 01:28PM |
LoboCNC
realthor
Now I wonder where can I find some double adhesive tape that is heat conductive and resistant to the temps of a heated bed while being thin enough to efficiently transfer the heat from the aluminum to the glass....
Gluing the aluminum to the glass will likely cause more warping that if the aluminum sheet were left unconstrained, due to the large difference in the thermal expansion coefficients between aluminum and glass. With the glass acting as an insulator, and if your silicone heater covers the entire back of the aluminum sheet, you'll probably get pretty even heat distribution across the aluminum and hence minimal warping. Also switching to 1mm thick aluminum will only reduce the heat spreading efficiency only slightly, but it will dramatically reduce the force required to keep the aluminum sheet pressed flat.
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 01:56PM |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 02:10PM |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 02:36PM |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 02:51PM |
LoboCNC
Gluing the aluminum to the glass across the entire surface will definitely cause warping - you are creating something very much like a bimetalic strip that is specifically designed to warp when heated. One solution to avoid a huge sandwich i you don't use any glue is to glue the aluminum to the glass in just a small spot in the center of the plate. With the the heater on the opposite side, the edges of the of the aluminum will want to warp upwards towards the glass and thus make good contact. This then leaves the aluminum to expand in length without trying to force the glass to expand at the same rate.
Also note that most aluminum sheet is not particularly flat to begin with. With 1mm sheet, I'd recommend gluing the center of the concave side to the glass so that the glass will pull it flat. With 1.5mm sheet, though, this may start to cause some significant warping of the glass.
BTW, I'm currently wrestling with the same issues with a 350mm^2 heated bed. I'm planning on skipping the glass altogether, but this gives me another set of headaches with keeping a relatively thin aluminum plate flat when heated. I'll let you know how that works out.
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 02:57PM |
Srek
Get rid of the glass, use a thicker plate made from cast aluminum and milled from both sides. It will warp very little, especially if you fix it in a way that it has a bit of give.
Use gluestick or 3dLac to make prints stick.
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 04:01PM |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 04:07PM |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 04:15PM |
realthor
Srek
I've found this, which isn't too expensive...
Would this be good enough?
http://www.ebay.de/itm/121254993166?clk_rvr_id=1035323292601&rmvSB=true
What techniques are there to " fix it in a way that it has a bit of give". Larger screw holes than the actual screws?
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 04:19PM |
Koko76
realthor
Srek
I use slotted counterbores in the plate (technically not a counterbore, since I have slots to the edge of the round bed). Shoulder screws in the holes. Bed rests on standoff. Shoulder screw and standoff are sized to allow the right space to load a wave washer to desired pressure. Plate is held down against the standoff with the wave washer, the head of the screw and the washer fit in the counterbore portion, nothing protrudes from the surface.
New build will be slight variation on that theme, with the addition of leveling adjustment, and no breaks in the surface whatsoever.
I use Mic6 for my beds, pretty flat and I want to say over 200mm a rise from 30deg to 100deg is in the neighborhood of .3mm change in length (calced not measured, but my arrangement keeps itself flat)
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 04:26PM |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 06:19PM |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 06:24PM |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 26, 2016 06:33PM |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 27, 2016 02:00AM |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 27, 2016 02:20AM |
Srek
Instead of the Teflon you can use the silicone i mentioned, it's the same though i would use smaller blocks since silicone is more elastic.
What the dentist shows is similar to how i solved this for my Dual Cube, the sunk screws are a simple and well working solution.
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 27, 2016 02:42AM |
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 27, 2016 03:14AM |
Srek
It might work, but it is difficult to glue silicone to anything.
My comment on the stability only realy applies if the bed is moving along Y.
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 27, 2016 07:09AM |
Srek
Re: Would 300x300mm glass plate bow if only supported by the 3 screws for leveling? May 27, 2016 07:18AM |
