Discussion on the Nimble
Posted by Lykle
Re: Discussion on the Nimble
December 14, 2016 01:42PM
You never know, you might spur him on? It's a pity, but we could all produce a single Z axis for £100 most of us already have one Z, what we really need is a small self contained resin bath add on so we can do high detail resin prints. Perhaps that part should be no more than a few hundred quid, it might be tricky for him to adjust to that, but someone will pull it off.
December 15, 2016 05:46AM
isn't just as simple as a resin batch you need a breathable build plate because ie if you tried to print for example a ping pong ball, when it gets drawn from the resin it cause a vacuum within the inner space, resin printers are messy too and more suited in my opinion for models that require such detail
Edited 1 time(s). Last edit at 12/15/2016 05:50AM by chris33.
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
December 15, 2016 02:14PM
Yes of course the attachment for the Z, but on reflection the reason this thing possibly didnt catch on may be more to do with the resin process, messy, small models, ornaments rather than more functional parts? and expensive.
