Heated Bed Stuck at 69c October 25, 2016 05:09PM |
Re: Heated Bed Stuck at 69c October 25, 2016 05:15PM |
Re: Heated Bed Stuck at 69c October 25, 2016 05:40PM |
Re: Heated Bed Stuck at 69c October 25, 2016 05:58PM |
Re: Heated Bed Stuck at 69c October 25, 2016 06:01PM |
Re: Heated Bed Stuck at 69c October 25, 2016 06:05PM |
Re: Heated Bed Stuck at 69c October 25, 2016 06:18PM |
Re: Heated Bed Stuck at 69c October 25, 2016 06:34PM |
Re: Heated Bed Stuck at 69c October 25, 2016 06:39PM |
Re: Heated Bed Stuck at 69c October 25, 2016 07:08PM |
DragonFire
It's probably in pins.h somewhere... which pins the geetech uses. Probably commented.
EDIT: No it isn't... you are going to have to check which board is defined in boards.h, then look through pins.h.
When you find the right entry for the board you have selected in boards.h, swap the TEMP_BED_PIN value for the TEMP_1_PIN value, to swap the inputs over.
Save, recompile, should fix it.
I tried the Geetech website, it doesn't seem to be working. If indeed it ever does... never tried it before.
