Marlin needs your help to go 32Bit November 18, 2016 10:59PM |
Re: Marlin needs your help to go 32Bit November 19, 2016 03:43AM |
Admin Registered: 13 years ago Posts: 7,003 |
Re: Marlin needs your help to go 32Bit November 19, 2016 03:49AM |
Do duet and smoothieware support dual x carriages?Quote
Dust
There is zero reason to port marlin and waste time and money and resources when these other better firmwares options already exist.
Re: Marlin needs your help to go 32Bit November 19, 2016 05:42AM |
Re: Marlin needs your help to go 32Bit November 19, 2016 06:00AM |
The Duet does https://duet3d.com/wiki/Configuring_multiple_independent_X-carriages_on_a_Cartesian_printerQuote
Srek
Dust
Re: Marlin needs your help to go 32Bit November 19, 2016 08:16AM |
Dust
I strongly disagree
Marlin is bloated, its old and hacked to bits and it makes many compromises just to barely function. (some of those are due to trying to run on an under powered processor)
If you want to support 32 bit firmware support the smoothieware guys or the duet firmware guys.
Re: Marlin needs your help to go 32Bit November 19, 2016 08:42AM |
Re: Marlin needs your help to go 32Bit November 19, 2016 01:36PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Marlin needs your help to go 32Bit November 20, 2016 03:31PM |
Re: Marlin needs your help to go 32Bit November 20, 2016 03:50PM |
Re: Marlin needs your help to go 32Bit November 20, 2016 04:52PM |
Re: Marlin needs your help to go 32Bit November 20, 2016 05:00PM |
nophead
>Smoothieware, running on a Smoothieboard, saves a lot of time, and to me that's a feature worth paying for.
Smoothieboard is an ironic name as it doesn't even do x16 microstepping accurately and has glitches in the the ADC. The last time I paid any attention to the software (which was admittedly a long time ago) it didn't even manage to coordinate the motors to stop at the same time.
Re: Marlin needs your help to go 32Bit November 20, 2016 05:25PM |
dc42
nophead
Ever tried RepRapFirmware?
Re: Marlin needs your help to go 32Bit November 20, 2016 06:15PM |
dc42
nophead
Re: Marlin needs your help to go 32Bit November 21, 2016 02:35AM |
nophead
dc42
Does it run on a Smoothieboard? I don't have a Duet.
Re: Marlin needs your help to go 32Bit November 22, 2016 04:11AM |
Re: Marlin needs your help to go 32Bit November 22, 2016 07:10AM |
Re: Marlin needs your help to go 32Bit November 22, 2016 09:05AM |
Re: Marlin needs your help to go 32Bit November 22, 2016 09:22AM |
Re: Marlin needs your help to go 32Bit November 22, 2016 09:30AM |
Re: Marlin needs your help to go 32Bit November 22, 2016 10:58AM |
DjDemonD
I also think they are innovating things like UBL to print objects onto uneven print beds and compensate to remove the unevenness from the object. That's a good idea, assuming that flat print beds are not always easy/cheap to achieve.
Re: Marlin needs your help to go 32Bit November 22, 2016 11:09AM |
Re: Marlin needs your help to go 32Bit December 01, 2016 05:34PM |
nophead
Re: Marlin needs your help to go 32Bit December 01, 2016 05:43PM |
Dust
Srek
Probably not, because your not supporting those firmware to request it, or better yet add those features yourself.
Also because its a feature that 99.999% of us don’t need
Re: Marlin needs your help to go 32Bit December 01, 2016 05:55PM |
Re: Marlin needs your help to go 32Bit December 01, 2016 06:03PM |
nophead
Well try G1 X 100 F1 and listen if the microstepping works. See [hydraraptor.blogspot.co.uk] for the reason it doesn't and the simple fix. This problem was well known in the RepRap world after my article so I was surprised to get a Smoothieboard with Rosc = 10K and found it ironic.
I stopped following on github, and it may have been two years ago, but at that point I read that the ADC produces bum samples of 0 or FFF due to a hardware bug and has to be filtered in firmware. The motors weren't synchronised due to the firmware being far too high level and modular and you were running out if program space. At that point I lost interest and it has been gathering dust. In the meantime my requirements for 3D printing have outgrown it.
Re: Marlin needs your help to go 32Bit October 08, 2017 05:10PM |
Re: Marlin needs your help to go 32Bit October 09, 2017 03:38AM |
Vido
I will stick with Marlin because Im sure that people who develop it will do even better job with 32-bit version, I cant wait for proper Re-Arm board
Re: Marlin needs your help to go 32Bit October 09, 2017 09:38AM |
