Circular 220mm heated bed for 220V? December 08, 2016 07:37AM |
Re: Circular 220mm heated bed for 220V? December 08, 2016 09:25AM |
Re: Circular 220mm heated bed for 220V? December 08, 2016 10:51AM |
Re: Circular 220mm heated bed for 220V? December 08, 2016 11:22AM |
Re: Circular 220mm heated bed for 220V? December 08, 2016 02:30PM |
Re: Circular 220mm heated bed for 220V? December 08, 2016 02:43PM |
Re: Circular 220mm heated bed for 220V? December 08, 2016 05:29PM |
Re: Circular 220mm heated bed for 220V? December 09, 2016 12:15PM |
Re: Circular 220mm heated bed for 220V? December 10, 2016 08:04AM |
Re: Circular 220mm heated bed for 220V? December 11, 2016 03:44AM |
Hi can you explain me a concept?Quote
dc42
You can order a silicone bed heater to whatever size, voltage and power you want from Shenzen Ali Brother Technology via Alibaba. They made me a 230V 350W 300mm one. The cost was around $35 AFAIR.
Re: Circular 220mm heated bed for 220V? December 11, 2016 06:17AM |
mdcompositi
dc42
I have a 24V 270W silicone bed and it take several minutes to go to 100°
How can I solve this issue? what kind you suggest me?
and how do you connect a 230V without damage risks?
If I have for example a 230V and 350W, what is the current ?
For example in my case I have 270/24=11,25A
Surely the basis of my reasoning there are gaps of knowledge but can you explain me how can I feed a 230V bed with a 24V power supply ??
Or If I can rephrase my question!!
What coupled bed +power supply you suggest me to gain temperature (100/120°) ASAP ?
Re: Circular 220mm heated bed for 220V? December 11, 2016 01:17PM |
Re: Circular 220mm heated bed for 220V? December 11, 2016 01:42PM |
mdcompositi
Gaou
sorry for hijackin the thread but what i am reading are very impressive.
i just installed my 270mm x 350mm 220v 600w heater in bottom of an 8mm aluminum 6061 ( i think). if you dont mind asking what kind of precautions did you took to protect the dc boards from a 220v leak- short ciruit..
Re: Circular 220mm heated bed for 220V? December 13, 2016 03:31AM |
dc42
First tell us the size and construction of your print bed, and what sort of printer it is.
Re: Circular 220mm heated bed for 220V? December 13, 2016 05:33PM |
mdcompositi
dc42
I have a custom corexy with a 300x300 aluminium plate (3mm thick) where I attached a silicone bed 24V 270W
I've read your page about how to connect a bed and I sensed (correct me if I'm wrong) that much is related to how the board is designed, how much current can support the tracks of the PCB
I have an ULTRATRONICS that have in correspondence of bed mosfet a 15A fuse
This makes me think that with any type of bed (12/24 or 230 V) must never exceed the current of 15A
with my configuration can reach 100 ° in twenty minutes !!
at this point I would like to be advised by you on what may be the best configuration to use(24 or 230 V I don't know)
In any case double power supply is needed?
.....and what kind of termistors silicone bed of alibrother use ? My bed (bought on aliexpres but don't remember where) had a fake termistor that I replaced with an other....
p.s. crydom SSR are very much expensive!! the cost as much as the electronics board!!
Re: Circular 220mm heated bed for 220V? December 14, 2016 12:19PM |
What do you mean when you say "your electronics can take it"??Quote
dc42
If your PSU has the usual voltage adjustment potentiometer, and it has enough power in reserve (e.g. a rating of 400W or more), and your electronics can take it, you could turn up the voltage to about 28V
Re: Circular 220mm heated bed for 220V? December 14, 2016 04:50PM |
mdcompositi
A last question..........
what are advantages/disadvantages about 12-24V DC or 230V AC?
Considering obviously the appropriate safety precautions?
Re: Circular 220mm heated bed for 220V? December 16, 2016 06:40AM |
Re: Circular 220mm heated bed for 220V? December 16, 2016 02:08PM |
Re: Circular 220mm heated bed for 220V? December 16, 2016 09:15PM |
Re: Circular 220mm heated bed for 220V? December 17, 2016 03:12AM |
Ok I'll buy this! 24V 360WQuote
dc42
300x300mm bed: 24V DC heater and electronics with 15A bed current rating
Re: Circular 220mm heated bed for 220V? December 17, 2016 04:02AM |
Andreas15
dc42, do you use bang-bang or PID with the AC heated bed?
Re: Circular 220mm heated bed for 220V? December 17, 2016 04:05AM |
mdcompositi
dc42
But I have two questions?
Do I have to use also in these case an SSR, just to be safe? Please can you link me here in Europe a seller about Auber relays
The bed that I have now was bought from alibrother and I had a problem with termistor (also using 13 in termistor bed string in marlin)
I had to replace it with a termistor used on e3dv6!!
Is this due to a construction defect?
I measured the temperatures of the two thermistors (alibrother-E3D) with an infrared thermometer and found temperature differences of 20 °
Re: Circular 220mm heated bed for 220V? December 17, 2016 04:15AM |
dc42
Whether or not you need an SSR depends on the bed current rating of your electronics. The cheaper electronics such as RAMPS can't handle 15A, but many of the better boards cam
Your thermistor reading issue was because you had the wrong thermistor parameters configured in your firmware.
Re: Circular 220mm heated bed for 220V? December 17, 2016 04:28AM |
Re: Circular 220mm heated bed for 220V? December 17, 2016 04:54AM |
Re: Circular 220mm heated bed for 220V? December 17, 2016 10:30AM |
Re: Circular 220mm heated bed for 220V? December 17, 2016 11:40AM |
Andreas15
I'm a bit in a dilemma with this one. Or going with an AC bed, or enlarging the whole frame to fit the 350W PSU, or finding a smaller PSU :p I don't know if it is worth all the safety requirements to go AC, but it just sucks to make the frame bigger to fit a PSU clean inside it. It really has to be in the base and I'm also not a fan of adding an extra extrusion under it to fit the power supply. Does anyone know a small(er) 350 or 360W power supply? The LRS-350 (30mm in height) is the smallest that I found, but the width and depth should have to be smaller too...
Re: Circular 220mm heated bed for 220V? December 17, 2016 01:11PM |
mdcompositi
dc42
I thought having to edit and recompile firmware to change parameters went out with the Ark - or at least with 8-bit electronics
Sorry .....what are you saying?? I don't understand.......
Re: Circular 220mm heated bed for 220V? December 17, 2016 01:15PM |
Andreas15
