New Reprap Printer, Calling it, the KittyCat! December 28, 2016 02:41AM |
Re: New Reprap Printer, Calling it, the KittyCat! December 28, 2016 04:40AM |
Re: New Reprap Printer, Calling it, the KittyCat! December 28, 2016 05:54AM |
Re: New Reprap Printer, Calling it, the KittyCat! December 28, 2016 06:14AM |
Re: New Reprap Printer, Calling it, the KittyCat! December 28, 2016 07:11AM |
Re: New Reprap Printer, Calling it, the KittyCat! December 28, 2016 11:34AM |
o_lampe
You've not drawn any corner brackets?
Re: New Reprap Printer, Calling it, the KittyCat! December 28, 2016 11:53AM |
Re: New Reprap Printer, Calling it, the KittyCat! December 28, 2016 12:05PM |
Re: New Reprap Printer, Calling it, the KittyCat! December 28, 2016 12:10PM |
Re: New Reprap Printer, Calling it, the KittyCat! December 28, 2016 11:36PM |
Re: New Reprap Printer, Calling it, the KittyCat! December 29, 2016 02:39AM |
Re: New Reprap Printer, Calling it, the KittyCat! December 29, 2016 03:38AM |
Re: New Reprap Printer, Calling it, the KittyCat! December 29, 2016 07:18AM |
MechaBits
Maybe use one dual shaft motor, for the Z and run a belt underneath(right through the cat litter) to other side.
I see this sort of layout as a well evolved version of the Prusa i3, especially if you go with a single motor Z and the thicker smooth rods. The next step up would be to expand the frame to a full cube so that it can be easily enclosed and go with either supported smooth rods or linear guides. That moves it far enough away from the original low cost motivation of the i3 design that it would be worth calling it something different (do we have anything like that as a documented open design?).
Re: New Reprap Printer, Calling it, the KittyCat! December 29, 2016 08:15AM |
Re: New Reprap Printer, Calling it, the KittyCat! December 29, 2016 08:35AM |
DjDemonD
Smartrapcore is probably the closest to that, okay its a corexy but it's an open source cuboid 2020 frame printer.
Re: New Reprap Printer, Calling it, the KittyCat! December 29, 2016 09:15AM |
Re: New Reprap Printer, Calling it, the KittyCat! December 29, 2016 09:19AM |
Re: New Reprap Printer, Calling it, the KittyCat! December 29, 2016 02:46PM |
DjDemonD
Totally agree, this design might be a good step up from an i3. But it's hard not to look at it and conclude it's just 4 slightly longer extrusions in y dimension from being a cube frame and being a much better printer for it.
Maybe this is the answer - start with this frame, then upgrade it to a cube frame, putting the replaced extrusions to one side to later make a z axis with, but with sliding y axis still and then upgrade it in a modular fashion to a corexy.
Re: New Reprap Printer, Calling it, the KittyCat! December 29, 2016 07:21PM |
Re: New Reprap Printer, Calling it, the KittyCat! December 29, 2016 07:47PM |
Re: New Reprap Printer, Calling it, the KittyCat! December 29, 2016 10:10PM |
Re: New Reprap Printer, Calling it, the KittyCat! January 03, 2017 08:02AM |
