Re: Re-Arm, any experiences? March 05, 2017 11:18PM |
Re: Re-Arm, any experiences? March 06, 2017 01:56AM |
Re: Re-Arm, any experiences? March 07, 2017 09:39AM |
Re: Re-Arm, any experiences? March 07, 2017 09:54AM |
Re: Re-Arm, any experiences? March 07, 2017 12:55PM |
Re: Re-Arm, any experiences? March 07, 2017 04:02PM |
Re: Re-Arm, any experiences? March 07, 2017 05:35PM |
Re: Re-Arm, any experiences? March 07, 2017 05:41PM |
Re: Re-Arm, any experiences? March 07, 2017 09:08PM |
sungod3k
Mine arrived today and im looking for a ramps delta sample config. I only could find the Cartesian sample here [panucattdevices.freshdesk.com].
Re: Re-Arm, any experiences? March 07, 2017 09:11PM |
Re: Re-Arm, any experiences? March 08, 2017 01:56AM |
Re: Re-Arm, any experiences? March 08, 2017 06:00PM |
Re: Re-Arm, any experiences? March 12, 2017 05:49PM |
there is no delta config for rearm at the moment, you need to grab the azteeg x5 delta config then carefully change all the pin numbers to match the re arm pins based on the re arm config. DOn;t try to do it the other way around though as deltas are very finicky about the config
Re: Re-Arm, any experiences? March 12, 2017 07:38PM |
Re: Re-Arm, any experiences? March 12, 2017 07:40PM |
Re: Re-Arm, any experiences? March 12, 2017 07:42PM |
Re: Re-Arm, any experiences? March 12, 2017 07:55PM |
Re: Re-Arm, any experiences? March 12, 2017 08:06PM |
Re: Re-Arm, any experiences? March 16, 2017 03:13PM |
Re: Re-Arm, any experiences? March 19, 2017 01:50AM |
Re: Re-Arm, any experiences? March 19, 2017 01:52AM |
Re: Re-Arm, any experiences? March 19, 2017 03:57AM |
sungod3k
@ DjDemonD your pins check out as far as i can see. I added a column indicating which pins are different when coming from the azteeg mini delat config.
Other question: what is the default model cooling fan pin? There are these switch.fan.output_pin and switch.misc.output_pin what is the difference here?
Re: Re-Arm, any experiences? March 19, 2017 10:59AM |
Re: Re-Arm, any experiences? March 19, 2017 12:49PM |
Re: Re-Arm, any experiences? March 23, 2017 11:11AM |
Re: Re-Arm, any experiences? March 23, 2017 11:19AM |
Re: Re-Arm, any experiences? March 23, 2017 01:07PM |
Re: Re-Arm, any experiences? March 23, 2017 02:03PM |
Re: Re-Arm, any experiences? March 23, 2017 02:09PM |
Re: Re-Arm, any experiences? March 23, 2017 05:52PM |
