Changing to mains-powered heatbeds May 07, 2017 07:12AM |
Re: Changing to mains-powered heatbeds May 07, 2017 07:35AM |
Re: Changing to mains-powered heatbeds May 07, 2017 11:52AM |
Re: Changing to mains-powered heatbeds May 07, 2017 01:06PM |
Re: Changing to mains-powered heatbeds May 07, 2017 03:40PM |
Re: Changing to mains-powered heatbeds May 08, 2017 05:28AM |
the_digital_dentist
If the existing heater is stuck to the aluminum using adhesive tape, that tape will probably be much older than the tape on the new heater. The old tape will probably let go of the bed before the new tape lets go of the old heater. If the tape fails, the heater may get hot enough to burn itself up (thermal runaway protection in your firmware may help here).
If you're going to attack the temperature problem, why not attack the flatness/warping problem too?
[www.instructables.com]
Re: Changing to mains-powered heatbeds May 08, 2017 05:33AM |
Re: Changing to mains-powered heatbeds May 08, 2017 05:35AM |
DjDemonD
If you want to go mains, do so I found there were far fewer pitfalls than I expected. My setup has a circular 320mm 700w silicone heater, a SSR 25DA unit which doesn't get hot, its running only about 10% of its rated capacity, a RCD for the printer and a 150 deg C thermal fuse between the silicone and the bed. I have ensured the entire frame and bed are earthed.
Heat up time is 3-4 minutes to 120 deg C.
That being said my other machine has a 200x300 pcb heater which I run from a second PSU on 24v DC, but using the 12v circuit on the PCB. The PSU is only 250w so its not really a risk for the PCB (possibly the PSU but its well cooled), and an external mosfet board. Probably 8 minutes to 120 deg C so not too shabby.
I use plenty of insulation on both, I can wait for parts to cool before detaching them.
Re: Changing to mains-powered heatbeds May 08, 2017 05:40AM |
Re: Changing to mains-powered heatbeds May 08, 2017 05:42AM |
Re: Changing to mains-powered heatbeds May 08, 2017 05:45AM |
Re: Changing to mains-powered heatbeds May 08, 2017 05:53AM |
Re: Changing to mains-powered heatbeds May 08, 2017 06:54AM |
Re: Changing to mains-powered heatbeds May 11, 2017 11:19AM |
Re: Changing to mains-powered heatbeds May 11, 2017 11:30AM |
Re: Changing to mains-powered heatbeds May 11, 2017 04:42PM |
Re: Changing to mains-powered heatbeds May 11, 2017 04:50PM |
animoose
Have you considered this: [hackaday.io]? It's a PCB heater rather than an Al plate, but otherwise looks good. I have bought one, but have yet to set it up.
Re: Changing to mains-powered heatbeds May 11, 2017 06:14PM |
animoose
Re: Changing to mains-powered heatbeds May 12, 2017 03:20AM |
