Re: Precision Piezo Z-probe Now available. June 18, 2017 01:42PM |
Re: Precision Piezo Z-probe Now available. June 18, 2017 02:40PM |
Hergonoway
since it seems that few people use the piezo on duet, did you directly connect the 5v pin of the piezo to the 3,3 VCC pin on the duet ? or is it related to the INT 5V_EN jumper ?
Re: Precision Piezo Z-probe Now available. June 18, 2017 02:43PM |
Re: Precision Piezo Z-probe Now available. June 18, 2017 05:11PM |
Re: Precision Piezo Z-probe Now available. June 19, 2017 05:23AM |
DjDemonD
Hergonoway
As ElmoC says its not 5v output from the Piezo 20 module if you supply it with 3.3v.
So on Duet its connected to the z probe connector the first pin (nearest the wifi module/sd card slot) is signal (3.3v), the next pin is ground, the last pin is the 3.3v output from the duet (which powers the piezo 20).
Hope this helps.
Re: Precision Piezo Z-probe Now available. June 19, 2017 05:28AM |
Re: Precision Piezo Z-probe Now available. June 19, 2017 12:44PM |
Re: Precision Piezo Z-probe Now available. June 19, 2017 01:14PM |
Re: Precision Piezo Z-probe Now available. June 22, 2017 06:50AM |
Re: Precision Piezo Z-probe Now available. June 23, 2017 03:24PM |
Re: Precision Piezo Z-probe Now available. June 23, 2017 03:30PM |
Hergonoway
ElmoC
I connected the 4 pin probe connector on the Duet right to the Piezo board. 3.3v to Vin, Gnd to Gnd, AD12 to Signal line.
Hi I've just switched to a duet, do you have an updated version of your configuration files since the last time?
M574 X2 Y2 Z2 S0 ; set endstop configuration (all endstops at high end, active high) M558 P1 X0 Y0 Z0 F120 T3000 H2 R0.2 ; probe is used for homing any axes G31 X0 Y0 Z0 P10 ; Set the zprobe height and threshold (put your own values here)
Re: Precision Piezo Z-probe Now available. June 24, 2017 04:27PM |
ElmoC
Hergonoway
ElmoC
The config file I posted was for use with the piezo probe. At least I think it was. I was having issues getting it to work consistently on my Cartesian printer, but it is working great on my delta. Here are the parts of the config file in regards to the probe.
Re: Precision Piezo Z-probe Now available. June 24, 2017 04:36PM |
Re: Precision Piezo Z-probe Now available. June 24, 2017 04:43PM |
Re: Precision Piezo Z-probe Now available. June 24, 2017 04:44PM |
Re: Precision Piezo Z-probe Now available. June 24, 2017 04:58PM |
DjDemonD
R is recovery time, I believe it waits for the specified time after a move to a probe point before beginning the probe. This cuts down on the effect of mechanical noise which seems more problematic on cartesian machines than deltas.
Re: Precision Piezo Z-probe Now available. June 24, 2017 05:00PM |
Re: Precision Piezo Z-probe Now available. June 24, 2017 05:06PM |
The other thing that's very useful is lowering acceleration, motor current and jerk before probing, then restoring it afterwards.
Re: Precision Piezo Z-probe Now available. June 24, 2017 05:18PM |
Re: Precision Piezo Z-probe Now available. June 24, 2017 05:55PM |
DjDemonD
I was trying to decipher the duet wiki about this. How are you using it?
M906 X1000 Y1000 Z1200 E600 ; Set motor currents (ma) M906 X500 Y500 Z500 H1 ; Set motor currents for probing
Re: Precision Piezo Z-probe Now available. June 24, 2017 05:57PM |
Re: Precision Piezo Z-probe Now available. June 24, 2017 05:59PM |
DjDemonD
Re: Precision Piezo Z-probe Now available. June 24, 2017 06:00PM |
Re: Precision Piezo Z-probe Now available. June 24, 2017 06:11PM |
dc42
DjDemonD
Once you have configured recovery time, reducing jerk should have no effect, because jerk is not used in Z probing moves. I wouldn't expect reducing motor current to be necessary either, unless you use low microstepping and the resulting vibration triggers the probe, whereas reducing motor current will make positioning less accurate. As for acceleration, the only one that should matter is Z acceleration, because a high acceleration at the start of the probing move could cause false triggering. Cartesian machines generally have low Z acceleration anyway. Delta machines can manage high Z acceleration, but it isn't necessary because Z acceleration doesn't affect printing speed the way X and Y acceleration do. So you may as well reduce Z acceleration generally if need be, not just during probing.
In summary, for a nozzle contact sensor I think it should be sufficient to configure enough probe recovery time for the sensor to recover after the travel move, and make sure that Z acceleration isn't too high especially on a delta or other machine with a belt-driven Z axis. That's also what we have found with the prototype Duet3D PCB effector.
If for any reason you do want to reduce motor current temporarily, use M913 in your bed.g file or in the macro that you use to do G29 bed probing. The M906 H parameter was only implemented in another user's fork of RRF.
2RepRapFirmware, DC42 version, cmm sub-version supports "H1"
Re: Precision Piezo Z-probe Now available. June 24, 2017 06:12PM |
Re: Precision Piezo Z-probe Now available. June 25, 2017 04:32AM |
Re: Precision Piezo Z-probe Now available. June 25, 2017 08:50AM |
Re: Precision Piezo Z-probe Now available. June 25, 2017 12:42PM |
Re: Precision Piezo Z-probe Now available. June 26, 2017 06:54AM |
