Re: Precision Piezo Z-probe Now available. July 20, 2017 05:43PM |
Re: Precision Piezo Z-probe Now available. July 20, 2017 05:59PM |
Re: Precision Piezo Z-probe Now available. July 20, 2017 06:55PM |
Re: Precision Piezo Z-probe Now available. July 21, 2017 01:26AM |
Re: Precision Piezo Z-probe Now available. July 21, 2017 03:44AM |
Re: Precision Piezo Z-probe Now available. July 21, 2017 07:57AM |
Re: Precision Piezo Z-probe Now available. July 21, 2017 06:18PM |
Re: Precision Piezo Z-probe Now available. July 23, 2017 07:36PM |
I could even make it so that I don't loose any z height.
But I will think about how I could make this work for that as well. Maybe a separate sensor that can be placed in the collet or attached using neodymium magnets to probe the bed with a known offset if the bed/plate/stock isn't conductive.|
Re: Precision Piezo Z-probe Now available. July 24, 2017 04:41AM |
Re: Precision Piezo Z-probe Now available. July 24, 2017 05:13AM |
Re: Precision Piezo Z-probe Now available. July 24, 2017 05:25AM |
imqqmi
Ok, please let me know what thread it is in case I miss it.
Re: Precision Piezo Z-probe Now available. July 24, 2017 05:29AM |
Precision Piezo Z-probe and Kit July 25, 2017 08:43AM |
Re: Precision Piezo Z-probe and Kit July 25, 2017 12:34PM |
Re: Precision Piezo Z-probe and Kit July 25, 2017 02:51PM |
Re: Precision Piezo Z-probe Now available. July 25, 2017 03:28PM |
Re: Precision Piezo Z-probe and Kit July 25, 2017 04:12PM |
DjDemonD
Yes, you would need to adapt the upper most part to hold the bed on in some way. What I envisaged was two sensor assemblies with corner shaped relief in them, and one with a flat sided relief, for the middle of the opposite side of the bed. Other than that I cannot see why not, but I'd consider using a 27mm version which would be these enlarged by 135%, as the 20mm version holds my circular 120mm bed nicely, but might not manage to hold a larger bed.
The way I'd approach this is copy my tinkercad design, model your printer's bed fixings on its carriage, and then the bed itself and then decide on what relief to but into the top parts, and whether to move the screw hole in the lower part to either suit your setup or as I have to ensure most of the sensor assembly sits under the bed, maximising pressure on the piezo itself.
See what you come up with.
Re: Precision Piezo Z-probe Now available. July 25, 2017 04:15PM |
Re: Precision Piezo Z-probe Now available. July 25, 2017 04:21PM |
Re: Precision Piezo Z-probe Now available. July 25, 2017 04:35PM |
Re: Precision Piezo Z-probe Now available. July 25, 2017 04:40PM |
Re: Precision Piezo Z-probe and Kit July 25, 2017 05:03PM |
Re: Precision Piezo Z-probe and Kit July 25, 2017 05:04PM |
Re: Precision Piezo Z-probe and Kit July 25, 2017 05:59PM |
Re: Precision Piezo Z-probe and Kit July 26, 2017 06:45AM |
Re: Precision Piezo Z-probe and Kit July 26, 2017 08:05AM |
Re: Precision Piezo Z-probe and Kit July 26, 2017 09:13AM |
Re: Precision Piezo Z-probe and Kit July 26, 2017 10:31AM |
Re: Precision Piezo Z-probe Now available. July 26, 2017 06:57PM |
Re: Precision Piezo Z-probe Now available. July 26, 2017 07:01PM |
