Re: Precision Piezo Z-probe Now available. March 11, 2018 08:17PM |
Re: Precision Piezo Z-probe Now available. March 12, 2018 07:28AM |
Re: Precision Piezo Z-probe Now available. March 12, 2018 08:01AM |
o_lampe
I found a counter-intuitive setting, which might be worth mentioning.
I had a deaf area on my bed ( underbed sensors ) where PP didn't trigger reliable. That caused the effector to bend and, cautious person I am, made me reduce probing speed ( works well with proximity sensors ). But it got worse. You have to raise probe speed ( 1000mm/s IIRC ) until you hear a nice tap.
Re: Precision Piezo Z-probe Now available. March 12, 2018 08:09AM |
Re: Precision Piezo Z-probe Now available. March 12, 2018 09:48AM |
Re: Precision Piezo Z-probe Now available. March 12, 2018 03:44PM |
Re: Precision Piezo Z-probe Now available. March 13, 2018 09:29AM |
Re: Precision Piezo Z-probe Now available. March 14, 2018 09:06AM |
Re: Precision Piezo Z-probe Now available. March 14, 2018 09:08AM |
Re: Precision Piezo Z-probe Now available. March 14, 2018 09:40AM |
Re: Precision Piezo Z-probe Now available. March 14, 2018 12:17PM |
Re: Precision Piezo Z-probe Now available. March 14, 2018 12:28PM |
Re: Precision Piezo Z-probe Now available. March 14, 2018 12:45PM |
Re: Precision Piezo Z-probe Now available. March 14, 2018 02:19PM |
Re: Precision Piezo Z-probe Now available. March 14, 2018 03:14PM |
Re: Precision Piezo Z-probe Now available. March 14, 2018 03:50PM |
Re: Precision Piezo Z-probe Now available. March 15, 2018 05:50AM |
Re: Precision Piezo Z-probe Now available. March 15, 2018 07:49AM |
Re: Precision Piezo Z-probe Now available. March 16, 2018 06:19AM |
whosrdaddy
Tekkydave, just put the piezo between the mount and xcarriage, this results in a more sturdy setup (and you gain some z-height in the process)
Thingiverse link
Re: Precision Piezo Z-probe Now available. March 16, 2018 06:53AM |
Re: Precision Piezo Z-probe Now available. March 16, 2018 06:55AM |
Re: Precision Piezo Z-probe Now available. March 16, 2018 07:08AM |
tekkydave
okercho - not sure who your question is to, but I'm just using a standard PP20 groovemount at the moment in my D-Bot corexy.
The only mod I have made to the electronics is to replace the VR2 pot with a 10-turn one. It's much easier to calibrate now. I wouldn't rcommend this mod unless your soldering skills are up to it. It would be very easy to damage the tracks if you're not very careful.
[attachment 103456 PP20.jpg]
Re: Precision Piezo Z-probe Now available. March 16, 2018 07:59AM |
Re: Precision Piezo Z-probe Now available. March 16, 2018 08:34AM |
okercho
whosrdaddy
Thingiverse link
I will give it a try in the CoreXY I'm rebuilding, but probably with a Bondtech instead of a Titan, although that should make no difference.
Are you getting good results with that setup? What Z Offset you've configured? Is the Xcarriage standard or you made modifications to put something that "press" more the disk?
Cheers!
Re: Precision Piezo Z-probe Now available. March 16, 2018 08:45AM |
whosrdaddy
Yes, is working like a charm. Z offset is -0.14 for my setup.
The back of the bracket houses a bit space for the piezo.
. Just curious, are you doing the probing with the nozzle cold or hot? I know is better (and recommended by the PrecisionPiezo guys) to do it hot, but in my setup I've found that the E3D fan is putting a lot of mechanical noise, so I've to turn it off, as even with 130C, PLA melted a bit, and sometimes (not always) caused clogs, so I always check my nozzle before probing (usually I go to 160C, clean the nozzle, cool it down to room temp and then make the levelling), and then just calibrate taking into account the expansion. Results are usually quite consistent.|
Re: Precision Piezo Z-probe Now available. March 16, 2018 09:44AM |
Re: Precision Piezo Z-probe Now available. March 16, 2018 10:00AM |
okercho
whosrdaddy
Cool, that's more or less what I've in my "traditional groovemount" setup, so the accuracy/pressure needed seems to be quite similar. Just curious, are you doing the probing with the nozzle cold or hot? I know is better (and recommended by the PrecisionPiezo guys) to do it hot, but in my setup I've found that the E3D fan is putting a lot of mechanical noise, so I've to turn it off, as even with 130C, PLA melted a bit, and sometimes (not always) caused clogs, so I always check my nozzle before probing (usually I go to 160C, clean the nozzle, cool it down to room temp and then make the levelling), and then just calibrate taking into account the expansion. Results are usually quite consistent.
Regarding the carriage, I saw in thingiverse the housing you mention in the bracket, but the carriage (the piece that has the bushings, sorry if it's not the correct word) is a "standard" unmodified one, right?
Regards
Re: Precision Piezo Z-probe Now available. March 16, 2018 10:07AM |
DjDemonD
I have started doing a bit more probing when cold. I think it does lower noise and perhaps improve accuracy, but it's harder to clean the nozzle and of more benefit if you can switch off your fans, which on more basic controller boards isn't usually an option.
Consider a noise cancelling piezo. I just bonded 3 under my corexy bed and suddenly it's working much better.
[attachment 103463 20180315_23325501.jpg]
They are the opposite facing to the sensors in the bed mounts so are wired in parallel. It now probes reliably, but I need to tweak it a bit to get really good accuracy.
Re: Precision Piezo Z-probe Now available. March 16, 2018 10:28AM |
Re: Precision Piezo Z-probe Now available. March 16, 2018 10:44AM |
