LokBuild, first impressions May 18, 2017 12:56PM |
Re: LokBuild, first impressions May 18, 2017 02:20PM |
Re: LokBuild, first impressions May 18, 2017 04:51PM |
Re: LokBuild, first impressions May 18, 2017 05:05PM |
Re: LokBuild, first impressions May 18, 2017 07:47PM |
Re: LokBuild, first impressions May 19, 2017 05:41AM |
Re: LokBuild, first impressions May 19, 2017 06:06AM |
Re: LokBuild, first impressions May 20, 2017 01:48PM |
Re: LokBuild, first impressions May 22, 2017 07:18AM |
Re: LokBuild, first impressions May 22, 2017 07:31AM |
Re: LokBuild, first impressions May 22, 2017 11:19PM |
Re: LokBuild, first impressions May 23, 2017 02:03AM |
Re: LokBuild, first impressions May 23, 2017 03:51AM |
Traveler0612
I have found that PEI lets go of ABS easily if you let it drop to 60 degrees Celsius first. On a rare occasion, I might need to gently slide a razor blade under the edge. PEI is the best surface I have used to date.
Re: LokBuild, first impressions May 23, 2017 10:27PM |
Re: LokBuild, first impressions May 25, 2017 12:42PM |
Re: LokBuild, first impressions May 25, 2017 04:47PM |
DjDemonD
I think that whilst lokbuild and printbite are discreet products Pei comes from a wide range of sources and I'm willing to bet is quite variable.
Re: LokBuild, first impressions May 25, 2017 09:49PM |
Re: LokBuild, first impressions May 26, 2017 02:20AM |
Re: LokBuild, first impressions May 26, 2017 09:39AM |
DjDemonD
I recently tried a sample of 3mm PEI and I printed some ABS onto it with my usual settings 250 first layer bed at 115 and it bonded to it so well I had to cut it off, ruined the PEI sheet. So that stuff works but IMO far too well. Might definitely keep a thin (cheap) sheet for when you absolutely, positively have to get a part to stick no matter what but doesn't seem as convenient for me as Printbite which with a thin ABS wash every now and again holds parts really well and importantly releases them predictably and at a sensible temperature so as not to slow the workflow down too much.
Re: LokBuild, first impressions August 04, 2017 02:05AM |
Re: LokBuild, first impressions August 04, 2017 11:41PM |
Re: LokBuild, first impressions August 05, 2017 11:04PM |
