Electronics for more silent printer May 19, 2017 06:07AM |
Re: Electronics for more silent printer May 19, 2017 06:46AM |
Admin Registered: 13 years ago Posts: 7,003 |
Re: Electronics for more silent printer May 19, 2017 06:48AM |
Re: Electronics for more silent printer May 19, 2017 06:56AM |
Re: Electronics for more silent printer May 19, 2017 06:57AM |
Re: Electronics for more silent printer May 19, 2017 07:10AM |
antidote314
I really don't want make any sort of modifications to electronics.
But are you saying that only by wiring the 24v to the steppers it will do the trick?
Re: Electronics for more silent printer May 19, 2017 07:17AM |
dc42
antidote314
To get 24V drive to the stepper motor drivers, you need to power the Duet from 24V. If you want to use a 12V bed heater, you can connect the +ve terminal of the bed heater to your +12V supply instead of to the output terminal on the Duet. Similarly for hot end heaters - although hot end heater cartridges are cheap so you might as well just swap the cartridge for a 24V one. Likewise, 24V fans are cheap; but if you want to go on using 12V ones, just remove the V_FAN jumper from the 3-pin jumper block and feed 12V from your PSU into the centre pin, then all fans will get 12V.
But do you really need to use 24V? The usual reason for needing a 24V supply for the stepper drivers is that you are using 0.9deg/step motors on a delta printer. 24V power allows the motors to maintain torque at higher speeds, but won't make your stepper motor drivers run cooler. If you know your motor specifications and what speed you want to achieve, you can work out how much drive voltage you need as described at [duet3d.com]. It's unlikely that you will need 24V drive on a Cartesian printer using 1.8deg stepper motors, unless they are low current/high inductance motors.
HTH David
Re: Electronics for more silent printer May 19, 2017 07:23AM |
Re: Electronics for more silent printer May 19, 2017 07:31AM |
antidote314
It seems like TMC2100 are making a little noise with voltage above 18v. That is my only reason.
antidote314
I can upgrade heater cartrige & my heated bed is controlled by SSR, so yes, Duet seems like awesome choice. 1024 thanks mate! :
Re: Electronics for more silent printer May 19, 2017 07:48AM |
Re: Electronics for more silent printer May 19, 2017 08:04AM |
dc42
antidote314
Ah, sorry I misunderstood. The driver on-time will be lower with a 24V supply than with 12V, so if the TMC2100 is using constant off-time switching then that may shift the switching frequency from audible to ultrasonic.
The TMC2660 drivers use a different algorithm, also it can be tweaked in firmware. So you may find that you can go on using 12V if you use the Diet WiFi or Duet Ethernet. [btw the Duet 0.6 and 0.8.5 are older boards with different drivers, so those are not what you are looking for,]
antidote314
Thank you! As mentioned in my signature, I have a financial interest in the Duet WiFi/Ethernet, so I can't claim to be independent. But I can honestly say that as 3D printer controllers, these boards can't currently be beaten except on price.
Here's a video I made that demonstrates how we try to protect users from some of their own mistakes.
[www.youtube.com]
Re: Electronics for more silent printer May 19, 2017 08:27AM |
Re: Electronics for more silent printer May 19, 2017 11:30AM |
Re: Electronics for more silent printer May 19, 2017 01:31PM |
Re: Electronics for more silent printer May 19, 2017 02:44PM |
Admin Registered: 16 years ago Posts: 13,889 |
Re: Electronics for more silent printer May 20, 2017 02:29AM |
