Re: Diamond hotends heatsink October 02, 2017 04:33PM |
Re: Diamond hotends heatsink October 02, 2017 04:45PM |
Re: Diamond hotends heatsink October 02, 2017 08:46PM |
deckingman
... one of more filaments may be heated but unused for a long period of time - an hour or more depending on the object being printed. It is under these circumstances that strange things start to happen which "single filament" users will not have experienced.
Re: Diamond hotends heatsink October 03, 2017 03:58AM |
frankvdh
deckingman
It seems to me that a workaround shouldn't be difficult -- ensure that every 30 minutes or so, all filaments are extruded by a few mm. This could be done as part of infill, or on a separate 'wipe' tower. Probably a g-code post-processor for Slic3r or Cura could be written?
Re: Diamond hotends heatsink October 05, 2017 09:11AM |
Re: Diamond hotends heatsink October 06, 2017 11:01AM |
Re: Diamond hotends heatsink October 15, 2017 05:32AM |
Re: Diamond hotends heatsink October 16, 2017 02:28PM |
Re: Diamond hotends heatsink October 16, 2017 03:41PM |
Re: Diamond hotends heatsink October 16, 2017 03:46PM |
Re: Diamond hotends heatsink October 16, 2017 03:52PM |
deckingman
I'm still not sure where you are going with this? Why don't you want to use the standard configuration and just fit 3 lite 6 heat sinks? They work fine on the 3 colour version.
Re: Diamond hotends heatsink October 16, 2017 03:57PM |
frankvdh
[www.aliexpress.com] lists
Teflon tube 030060PT 3*6mm 3mm 6mm Gas or liquid; `-190 to 280 degrees Celsius
If 3mm ID is too big, you could maybe use a 2*3mm tube inside that?
Teflon tube 020030PT 2*3mm 2mm 3mm Gas or liquid; `-190 to 280 degrees Celsius
AFAICT, PTFE is only sold in metric sizes.
Re: Diamond hotends heatsink October 16, 2017 07:32PM |
fma
You're suggesting to put a short brass tube inside the 6x3 PTFE tube, in the Diamond threaded space?
And then go up to the extruder with the 3x2 PTFE tube?
Re: Diamond hotends heatsink October 17, 2017 01:09AM |
frankvdh
My thinking is that 6mm PTFE might not have much depth into an M6 thread, so the brass tube would stop the PTFE from collapsing and therefore stay in the fitting better.
Re: Diamond hotends heatsink October 17, 2017 03:11AM |
fma
deckingman
Yes, but if they are only usefull for fixation, why bother with such huge piece of metal? And if it works, it could solve your problems with the 5 colours... And make a cheaper config.
Re: Diamond hotends heatsink October 17, 2017 04:10AM |
