Re: Thoughts on a beginner CNC April 19, 2018 03:42AM |
Re: Thoughts on a beginner CNC April 19, 2018 11:04AM |
Re: Thoughts on a beginner CNC April 19, 2018 11:49AM |
Re: Thoughts on a beginner CNC April 19, 2018 01:25PM |
Re: Thoughts on a beginner CNC April 21, 2018 05:18AM |
I'm not expecting (or claiming) great things. This isn't supposed to be a super machine, just a machine for someone who wants to use one but can't afford the expensive offerings out there. Early RepRaps produced appalling prints, but people still made, wanted and bought them because spending $10,000 dollars on a "proper" tool is out of the question for most people. I'm planning to take an approach like the MPCNC and use steel tubing. I've thought about MDF but don't like how temperature/humidity sensitive it is. I've considered using plastic sheet like acetal instead of MDF but for the moment steel tubing seems like the better approach.Quote
Origamib
Buy a router and a guide rail for £100 and make the whole thing out of MDF. You could make grooves in the MDF that delrin rollers (or cheap DIY wheels of some sort) can roll in. The router can then be used on the machine afterwards.
Don't expect a large build area, and don't expect great things. But it should do well enough to get someone started. Aside from that, how else can you make a CNC for less then £300?
Way ahead of you. Using braided fishing line for the drive, by delrin sliders I'm assuming the v wheels used by openbuilds? I'm going a step more budget (possibly more rigid) with plain radial bearings.Quote
o_lampe
If you want to keep the cost low, why not try to adapt the Delrin slider idea and use heavy duty fishing line for the drive?
Both are cheap to get and the pulleys and brackets are printable.
Re: Thoughts on a beginner CNC April 21, 2018 07:53AM |
Re: Thoughts on a beginner CNC April 21, 2018 09:27AM |
Re: Thoughts on a beginner CNC April 21, 2018 04:05PM |
Re: Thoughts on a beginner CNC April 21, 2018 04:06PM |
Re: Thoughts on a beginner CNC April 22, 2018 12:38AM |
Re: Thoughts on a beginner CNC April 22, 2018 03:33PM |
Re: Thoughts on a beginner CNC April 22, 2018 05:58PM |
Re: Thoughts on a beginner CNC April 22, 2018 08:09PM |
Re: Thoughts on a beginner CNC April 22, 2018 09:04PM |
Re: Thoughts on a beginner CNC April 22, 2018 09:08PM |
Re: Thoughts on a beginner CNC April 22, 2018 10:14PM |
Re: Thoughts on a beginner CNC April 22, 2018 11:36PM |
Re: Thoughts on a beginner CNC April 23, 2018 01:11AM |
Re: Thoughts on a beginner CNC April 23, 2018 03:20AM |
Re: Thoughts on a beginner CNC April 23, 2018 04:26AM |
Re: Thoughts on a beginner CNC April 23, 2018 01:58PM |
Re: Thoughts on a beginner CNC April 23, 2018 05:10PM |
Re: Thoughts on a beginner CNC April 23, 2018 06:07PM |
Re: Thoughts on a beginner CNC April 23, 2018 06:20PM |
Re: Thoughts on a beginner CNC April 24, 2018 03:04AM |
andornot
...we are also building a cnc machine with interchangeable heads, although it will not be a £200 machine. Its loosely based on a routing machine, using linear slides, lead screws and nema 23 motors. We are adding linear encoders to a smart drivers to each of the axis to give an accurate positioning system.
The cnc with be controlled via a smoothieboard interfacing with a touch screen. The interchangeable heads we designing initially will be routing head, 3d printing, laser engraving, waterjet cutting and uv piezoelectric resin printing. Bed size approximately 800 x 600.
Trakyan
Any links to the machine?
Re: Thoughts on a beginner CNC April 24, 2018 04:05AM |
Re: Thoughts on a beginner CNC April 24, 2018 05:23AM |
Trakyan
Sounds like an awesome machine. I imagine a machine like that would be fairly costly with all those bells and whistles. Is it open source? There aren't many waterjet cutters out there and I wish those were more accessible. Also by UC piezoelectric resin printing, I assume you mean sort of like the objet systems? If so, also really cool. Any links to the machine?
Re: Thoughts on a beginner CNC April 24, 2018 11:09PM |
I'm just interested in machines that do cool stuff, then I try and find a way to do it for cheap. Sort of figured it was self promotion but I was hoping it might be open source as well.Quote
o_lampe
Why do you fall for this selfpromoting BS? Keep the thread close to your subject...The other machine is nowhere near your specs.
SQLException
To be honest I don't get whats the purpose of this thread either. Conversation jumps back and forth. First question I read was: "how much would you pay for a budget machine" (for buying a kit, over sourcing all parts yourself). Although it looks like you just want to hear how much people would buy a CNC kit for so you can put the right pricetag on your (soon finished?) CNC. But then you said its not marketting here so idk. Lets stick to the initial question...
Its 500$. My MPCNC (link: [www.youtube.com] & [www.v1engineering.com]) costs <400$ to make, 2 weeks of non-stop printing and a couple more hours to assemble.
About the "shit is too expensive in my country" problem: most parts you can order in China (Router, Electronics, even the screws and filament - not recommended though!). The only thing I actually bought NOT in China was the rails (shipped from Austria to my country), those were wardrobe rails, super cheap, suprisingly good quality in terms of finish and straightness.
Thats it, cant give more input on this topic since its not clear what your asking for (other then pricetag opinions). If its just for chit-chat: I'm fine with it, I'm also interested in new machines, too.
Re: Thoughts on a beginner CNC April 25, 2018 02:15AM |
Re: Thoughts on a beginner CNC April 25, 2018 03:57AM |
Trakyan
Here are my main questions:
What would you use a CNC for? If you can mention the sort of size and or tolerances you think you'll need, go ahead and mention that.
What sort of budget do you have for this machine? I'm not here hoping to hear $10000 so I can throw in a markup, I'm here expecting to hear $300-400 dollars so I can figure out what price point I need to build down to. What do I have to get rid of to hit that price point, or (with any luck), what extra features can I add in before it gets too expensive? Stuff like homing, touch plates, clamps, upgraded components and so on.
What, other than the hardware of the machine itself, do you think is important? Providing software tool chains, assembly instructions, getting started guides, customer support... etc...
