Re: Thoughts on a beginner CNC April 25, 2018 04:17AM |
I'm not sure whether that's a case of the questions being biased or I'm asking a specific audience. I've tried CNC-zone and got no response whatsoever, any suggestions for where else I could ask? I'm also fairly sure there are people here who are interested in CNC routers for reasons other than 3D printer upgrades, myself included. I doubt any of the people who chipped in here as owners of a CNC router built it for the purpose of upgrading their 3D printer.Quote
Origamib
Your questions are inherently biased. You're asking a 3D printing forum what they want... The answer is the ability to cut metal to 0.1mm or better and a build size of 300m2 or bigger. The main use will be for 3D printer upgrades.
The cost is obviously between £300 and £700. The higher end is approaching current machines on the market and the lower end may not even be possible. These answers are quite obvious...
Origamib
Now, ask a wider audience and you will get a better response. Perhaps most people are happy with +/- 1mm and only want to make furniture, household decorations and stuff they can sell on etsy.
What do you want? What do you think is possible at this price point? The lower price will require more thought on the design, and you are the designer.
Re: Thoughts on a beginner CNC April 25, 2018 09:44AM |
Trakyan
Me? I'm after a fairly large format machine. I plan to use it for largish woodworking projects like longboard decks and furniture and stuff around the house. I also intend to use it for some small aluminium pieces. I know those two are at odds with each other but if I go with a steel tube construction like I'm currently planning it won't be hard to switch between the two if I need to for rigidity reasons. I personally don't need any more than +-0.1 mm, but I'd like to know what other are wanting. I'm fairly sure that these goals are achievable since I hear about similar results with the MPCNC, and I plan to make my design beefier and more rigid.
Re: Thoughts on a beginner CNC April 25, 2018 10:09AM |
Re: Thoughts on a beginner CNC April 25, 2018 07:22PM |
Except it's not about what I want. The course is about a business venture, that means the product has to adhere to what the market wants not what the creator wants. Origamib asked for my opinion on the subject, I answered.Quote
MKSA
OK, so you answered your own initial question.
So based on what you want, just go ahead and "design" your machine. At least it will fulfill your requirements and may be others too.
Re: Thoughts on a beginner CNC April 26, 2018 12:05PM |
Re: Thoughts on a beginner CNC April 26, 2018 08:27PM |
Re: Thoughts on a beginner CNC May 07, 2018 01:54AM |
Re: Thoughts on a beginner CNC May 07, 2018 05:28AM |
Re: Thoughts on a beginner CNC May 07, 2018 08:44AM |
Re: Thoughts on a beginner CNC May 07, 2018 02:54PM |
MechaBits
Funny you should say that, it was a skip find....it's 2 inch thick,
but just wood chips & melamine...I got 3 pieces.
If I want a granite slab its Home Bargains for 4.99
but the other week at a party, I met the local stonemason,
we talked marbles, and how I needed some accurate holes drilling,
he said to call up to the local cemetery some time and pick up some of his pieces he's been saving
and the lads will put some holes in it....
Re: Thoughts on a beginner CNC May 07, 2018 05:02PM |
Re: Thoughts on a beginner CNC May 12, 2018 04:02PM |
Re: Thoughts on a beginner CNC May 13, 2018 07:28AM |
Re: Thoughts on a beginner CNC May 23, 2018 09:55PM |
Re: Thoughts on a beginner CNC May 23, 2018 11:17PM |
Re: Thoughts on a beginner CNC May 24, 2018 11:09AM |
