Stackable, printed extrusions that can be filled with resin April 26, 2018 02:46PM |
Re: Stackable, printed extrusions that can be foam filled April 26, 2018 03:15PM |
Re: Stackable, printed extrusions that can be foam filled April 26, 2018 03:30PM |
Re: Stackable, printed extrusions that can be foam filled April 26, 2018 03:40PM |
the_digital_dentist
Are you going to print them and try injecting them with foam?
Origamib
Why not just print 100mm high extrusions? I have successfully done this before using the CAD files supplied by openbuilds. I used them to make a 3D scanner I designed before buying the correct lengths of extrusion.
EDIT: a better idea would be to remove the locating pins and instead design long strips that slide into the channels. The diameter of the center hole can then be larger to accommodate more foam.
Re: Stackable, printed extrusions that can be foam filled April 26, 2018 06:41PM |
Re: Stackable, printed extrusions that can be foam filled April 26, 2018 06:43PM |
Re: Stackable, printed extrusions that can be foam filled April 26, 2018 07:23PM |
Re: Stackable, printed extrusions that can be foam filled April 26, 2018 08:50PM |
Re: Stackable, printed extrusions that can be filled with resin April 26, 2018 09:00PM |
Re: Stackable, printed extrusions that can be filled with resin April 26, 2018 09:06PM |
the_digital_dentist
Have you calculated the cost of this "extrusion" compared to aluminum?
Re: Stackable, printed extrusions that can be filled with resin April 26, 2018 09:11PM |
Re: Stackable, printed extrusions that can be filled with resin April 26, 2018 09:15PM |
the_digital_dentist
That does look nice! Who makes the filament?
Re: Stackable, printed extrusions that can be filled with resin April 26, 2018 10:14PM |
Re: Stackable, printed extrusions that can be filled with resin April 26, 2018 10:27PM |
the_digital_dentist
I've put UV LEDs inside fluorescent plastic parts before and it was very disappointing. The UV makes the surface it hits glow, but it doesn't penetrate the plastic, so the effect is very weak.
I print using fluorescent filament at Maker Faires and have about 20W of UV LEDs installed in my printer. I like to use FoxSmart Screamin' Green TPU but that pink stuff looks really nice, too. I'll have to get some.
Re: Stackable, printed extrusions that can be filled with resin April 26, 2018 11:14PM |
Re: Stackable, printed extrusions that can be filled with resin April 26, 2018 11:25PM |
the_digital_dentist
I bought a bunch of 1W UV LEDs (get the cheap ones- 400 nm- the 360 nm cost a LOT more and don't cause any brighter fluorescence), a couple strip type PCBs, and then mounted them on aluminum angle stock to direct the light and dissipate heat. I power them with a $8 dc-dc converter set for about 19V out which puts about 20W into the 30 LEDs so they'll live a long, happy life. See [drmrehorst.blogspot.com] I put a few in the top of the machine pointing down on the bed and then two long vertical strips on either side of the clear PC front panel. The way I have arranged the lights you can't see them directly when you look into the front of the printer, but they reflect off the walls very nicely and give a nice effect in photos.
This pictures is with the original UV LED strips I used which were not bright enough, and before I added light to the top of the printer.
I have about 18W of white LEDs arranged on the top and alongside the vertical UV lights in the front of the machine.
Re: Stackable, printed extrusions that can be filled with resin April 26, 2018 11:30PM |
Re: Stackable, printed extrusions that can be filled with resin April 27, 2018 01:58AM |
Re: Stackable, printed extrusions that can be filled with resin April 27, 2018 02:07AM |
Re: Stackable, printed extrusions that can be filled with resin April 27, 2018 02:56AM |
Re: Stackable, printed extrusions that can be filled with resin April 27, 2018 03:07AM |
Re: Stackable, printed extrusions that can be filled with resin April 27, 2018 03:09AM |
mars on the rocks
I've printed the 30x30 and filled it with foam and as a test I printed it again with 5% infill and its seems just as strong.
Re: Stackable, printed extrusions that can be filled with resin April 27, 2018 03:15AM |
Re: Stackable, printed extrusions that can be filled with resin April 27, 2018 03:19AM |
mars on the rocks
I got it to cure but it didn't have a top I still got voids though I think this technique might better suit thinner walled objects as far as strength goes but between 3 and 5% infill with 4 shells should be strong enough for a 3d printer and wouldn't use to much more filament
Re: Stackable, printed extrusions that can be filled with resin April 27, 2018 03:26AM |
Re: Stackable, printed extrusions that can be filled with resin April 27, 2018 06:47AM |
klcjr89
o_lampe
When I use foam for a close gap, I use a mist water sprayer before I inject the foam.
I might try this, as the casting resin is very expensive and the volume required to fill the cavity would be astronomical.
Re: Stackable, printed extrusions that can be filled with resin April 27, 2018 04:49PM |
klcjr89
Thanks for the info, do you think I could use such 400nm UV LEDs to directly light up the extrusions if I place them within the extrusions?
Re: Stackable, printed extrusions that can be filled with resin April 27, 2018 05:12PM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: Stackable, printed extrusions that can be filled with resin April 27, 2018 05:23PM |
Re: Stackable, printed extrusions that can be filled with resin April 27, 2018 06:18PM |
