Re: Early prints May 06, 2011 01:27PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Early prints May 07, 2011 04:49PM |
Re: Early prints May 07, 2011 06:22PM |
Re: Early prints May 07, 2011 07:37PM |
Re: Early prints May 07, 2011 07:45PM |
Re: Early prints May 07, 2011 08:32PM |
Re: Early prints May 07, 2011 08:44PM |
Skeinforge manual
Default: 1.5
This parameter tells skeinforge how thick the extrusion is expected to be in relation to the layer thickness. The effect of increasing this is to cause the lines that create the infill to be further apart. So if your solid base infill is sparse decrease the value. If solid infill appears too full increase the value. Infill Perimeter Overlap (ratio) also effects solid infill by shortening the lines. If you look at a solid base layer that has been laid down on glass or tape without a raft you can often see how the plastic flows and see which to alter for the best result.
Re: Early prints May 07, 2011 08:54PM |
Re: Early prints May 07, 2011 09:17PM |
Re: Early prints May 07, 2011 10:16PM |
Re: Early prints May 07, 2011 11:18PM |
Re: Early prints May 07, 2011 11:41PM |
Re: Early prints May 08, 2011 02:36AM |
Re: Early prints May 08, 2011 02:52AM |
Re: Early prints May 08, 2011 02:54AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Early prints May 08, 2011 02:56PM |
Re: Early prints May 08, 2011 03:08PM |
Re: Early prints May 08, 2011 07:51PM |
Re: Early prints May 09, 2011 02:23AM |
