Design Review! Looking for comments / critiques and ideas for my new printer build. November 24, 2018 03:11PM |
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 24, 2018 06:35PM |
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 24, 2018 07:19PM |
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 25, 2018 01:22AM |
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 25, 2018 02:25AM |
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 25, 2018 02:32AM |
Ed3D
Ive been looking at your differential IR sensor and it looks great. I think it might fit my machine a bit better due to its size and shape. Do you have the dimensions of it so I can make a solid model (or even better a solid model of it!)?
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 25, 2018 08:12AM |
the_digital_dentist
Print head: covering the ugly hot-end with fans and plastic shrouds, etc. makes it look "professional", but tends to make it a PITA to service, and the extruder is going to be the least reliable thing in your printer- you will have to service it from time to time. Make sure you can take it apart and get it back together easily. Think about where the fan wires and all the other wires are going to be routed and anchored. Think about how you're going to reach screws with tools while the thing is inside the machine.
the_digital_dentist
X axis: 5mm plywood isn't going to do much for rigidity, and plywood will fail over time, especially when exposed to heat. If you have to have something to support the X axis rail, cut a piece of aluminum, t-slot, or even rectangular aluminum tubing. It will be light, rigid, and won't warp or delaminate like plywood. Plywood is generally a terrible material for use in a 3D printer.
the_digital_dentist
Y axis: Verify that the t-slot material has a flat surface for the guide rails to sit on- some are concave.
the_digital_dentist
E axis: I've used belt tensioners like that before and switched to other designs, mostly because it can be difficult to get a tool into the adjuster screw when the belt is in place. Of course, you should only have to tension the belts once, so it isn't a major problem.
the_digital_dentist
Z axis: 4 guide rails is asking for alignment trouble and completely unnecessary. Two is plenty, placed close to two of the lead screws. Anti backlash nuts shouldn't be necessary.
the_digital_dentist
Bed: excessive corner bracing, simple L brackets can attach the bed support to the bearing blocks. Don't glue a heater to a piece of glass - poor thermal performance, and a problem if you break the glass (it happens). Use 3 levelers for the same reason you use 3 lead screws.
the_digital_dentist
Frame: excessive corner bracing, especially for such a small printer with such large cross-section frame members. You shouldn't need the corner brackets at all if the ends of the frame members are cut square and to matching lengths. Is it cheaper/easier to use 3030 frame pieces and tons of corner braces and hardware or 3030 (or even 4040?) frame members with ends milled square? If you build it without the corner braces, you can always add them later if you think it needs it, and if it doesn't you saved yourself some money and a lot of messing around. Make leveling feet using bolts that screw into the axial holes in the vertical frame members. You can print TPU caps to cover the heads of the bolts.
the_digital_dentist
Electronics: enclosure is nice, but it's best if you can access the electronics while the printer is operational, especially when you're first setting up the machine, but also for servicing. If you put electronics on the bottom, you either have to turn the machine over to access the electronics or have to raise the bed so you can remove the top cover of the enclosure. If you need to service the machine because it isn't working, how are you going to raise the bed? Put a crank on one of the lead screws? Putting electronics in a drawer at the bottom or on top of the machine are workable solutions if you don't want to increase the footprint by putting electronics on the side or back of the machine.
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 25, 2018 10:28AM |
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 25, 2018 03:15PM |
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 25, 2018 11:23PM |
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 26, 2018 01:43AM |
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 26, 2018 01:15PM |
ED3d
Excessive isnt bad though - the brackets are only 3D printed so cheap and dont take that long to print. They also function to hold the bottom paneling in place. I think blind joints with the plastic corners will be enough to give it rigidity though and it saves me buying a ton of those really expensive corner pieces. Ill have a play around with it and see what I can come up with.
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 26, 2018 01:57PM |
o_lampe
Guiding the belt like you showed for the Z motor requires a very long belt. A simple triangle with some extra wrap around the stepper pulley will do.
MKSA
Seeing this, I experience "deja vu"
Indeed, in the coreXY thread (and others regarding the misuse of linear rails), plenty of similar request for reviews with pretty much the same design errors.
SO why not first study the couple of machines that have been built and really work well then try to improve eventually on their design or as good but cheaper, easier ....
I know the saying: "we learn more from our mistakes than success". Yet I think we can save time by learning from other's mistakes.
jinx
corner brackets dont have to be expensive some aluminum L profile a hack saw, drill and some time will do.
never found a Lprofile that was true square so some,,,a lot of time with a hand file to get a true right angle but its well worth the effort.
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 26, 2018 03:57PM |
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 26, 2018 04:37PM |
SupraGuy
In general, I like it.
SupraGuy
I'm a little unsure however what advantages it offers over something like the Railcore. It seems to me that if I'm going to be buying linear guides, extrusion and all of the plates, for a CoreXY build, there's already an existing solution out there that does all that that's already been debugged, and issues identified.
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 27, 2018 05:45AM |
Ed3D
MKSA
Thanks - very helpful.
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 27, 2018 05:54PM |
So theres a few differences to the railcore - but it did provide a fair bit of inspiration. I think the main differences are the different rail arrangement, the frame thickness, and the 3x lead screw setup.
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 28, 2018 05:31PM |
Ed3D
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 29, 2018 04:15PM |
SupraGuy
In any case, I was asking what ADVANTAGES, not what differences.
I understand well the appeal of designing something different. Other design features were copied and emulated as closely as I was able from known good and working designs, as I felt no need to re-invent parts of the design which already existed and were perfectly adequate.
SupraGuy
I'm unsure that the thicker extrusion offers much advantage. I don't think that the 2020 extrusion flexes under the kinds of loads that the printer puts on it. Any flex comes from corner joints. You have addressed that, but then so do many other designs, and I didn't see any innovative deviation there. If anything,I'd bet that the full sheet approach that the Railcore took is ultimately a superior solution in terms of frame squareness and rigidity, and does not have a lot of extra cost to it.
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. November 29, 2018 05:02PM |
I kind of thought that asking about that was a comment on the design, which is what you're asking for.Quote
Ed3D
Does it have to have any advantages? If I wanted a printer I'd just go out and buy one. If I wanted to build something than I'd have posted asking for printer kit recommendations. This for me is about designing something, understanding the mechanics of it and making something that's my own design. It doesn't have to be innovative. You say I should copy other designs that I know work... well that's exactly what I've done - I didn't invent CoreXY, using three lead screws, linear rails on axis, etc etc. A new design doesn't have to break new ground, it can simply be an assimilation of things I like from other designs. This is off topic for this thread though so can we get back to the focus?
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. December 01, 2018 12:11AM |
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. December 01, 2018 07:24AM |
MKSA
Would it be possible also to move this in the correct topic, CoreXY, eventually in a sub category "in progress" for follow up.
So many similar projects that get buried in the "general" discussion.
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. December 01, 2018 08:30AM |
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. December 01, 2018 02:24PM |
the_digital_dentist
I'm not sure what numbers it would take to prove it, but I suspect that square tubing is both lighter and stiffer than an equivalent size t-slot, and you can pick it up at your local hardware store.
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. December 01, 2018 07:43PM |
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. December 02, 2018 03:01AM |
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. December 02, 2018 05:24AM |
mcdanlj
My chiwin rails ran better (smoother, less resistance, more consistent) after I attached them to 2020 (using a very tight jig to make sure they were parallel all along the length) than they did unsupported, for what it's worth.
mcdanlj
Hardware store aluminum in my experience is usually pretty soft. Around here, 6061 is the most widely available strong alloy.
o_lampe
Interesting numbers!
But torsional forces are not neglectible, when you mount the extruder to one side of the Y-beam/rail.
I guess, in that discipline the square tube finishes second compared to T-slot and the I-beam is third?
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. December 02, 2018 06:12AM |
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. December 02, 2018 06:18AM |
I beam: 91.42 grams. 2.81 microns max deflection. Box Beam: 116.64 grams. 1.33 microns max deflection. 2020: 136.12 grams. 1.50 microns max deflection.
MKSA
May be, just some clarification please.
Why is the 300g weight for carriage (hot end included ?)
MKSA
the 3N in Y , the 3m/s² requires indeed 0.9N but why added to gravity in Z ?
MKSA
How is the total deflection computed ? And where ?
Re: Design Review! Looking for comments / critiques and ideas for my new printer build. December 02, 2018 09:03AM |
