i have checked a previous thread that may help you with linux install on ubuntu. i know there are other linux distributions. just thought this may help you.
forums.reprap.org]
also gen 6 data is here [
reprap.org]
reprap install under linux [
reprap.org]
as far as i can tell the usb is just a serial to usb converter, and the driver should be easily installed.
some people have issues with the java version installed. i think version 9 of ubuntu works ok. i found these instructions helpful for me for getting preview to work with replicatorg [
replicat.org]
as far as i can tell yes, it is compatible. I'm sure some other people will pipe in with there 2 cents worth. good luck!
