Building the largest 3d printer I think ![]() November 08, 2019 02:50AM |
Re: Building the largest 3d printer I think ![]() November 08, 2019 03:31AM |
Admin Registered: 13 years ago Posts: 13,033 |
Re: Building the largest 3d printer I think ![]() November 08, 2019 08:22AM |
Re: Building the largest 3d printer I think ![]() November 08, 2019 06:07PM |
Admin Registered: 8 years ago Posts: 3,093 |
Re: Building the largest 3d printer I think ![]() November 08, 2019 10:16PM |
Re: Building the largest 3d printer I think ![]() November 09, 2019 12:51AM |
the_digital_dentist
Here's a calculator that will tell you how long it will take to heat the bed based on its construction and the power applied: [jscalc.io]
You can have a custom heater made to fit that size bed- Keenovo will do it for a reasonable upcharge over their off-the-shelf stuff.
Is this your first 3D printer design/build?
Re: Building the largest 3d printer I think ![]() November 09, 2019 12:53AM |
Re: Building the largest 3d printer I think ![]() November 09, 2019 01:19AM |
Re: Building the largest 3d printer I think ![]() November 09, 2019 01:42AM |
For that size, you want a 1kW heater, not 0.1kW, unless you are fine on waiting 1 or 2 hours for print bed to heat to 55C.Quote
EzyMan
Power Input (W):
100
Length of Plate (mm):
800
Width of Plate (mm):
800
Re: Building the largest 3d printer I think ![]() November 09, 2019 02:25AM |
piper3d
EzyMan
Power Input (W):
100
800
800
In general (no offense) looks like you do not know what you are doing.
You may go either:
1. experience way - start with a smaller printer like 300x300,
2. or knowledge way and repeat somebody else well documented and supported open-source design.
Re: Building the largest 3d printer I think ![]() November 09, 2019 04:01AM |
Re: Building the largest 3d printer I think ![]() November 09, 2019 04:15AM |
Re: Building the largest 3d printer I think ![]() November 09, 2019 09:39AM |
Re: Building the largest 3d printer I think ![]() November 10, 2019 08:05PM |
Re: Building the largest 3d printer I think ![]() November 13, 2019 05:43AM |
Re: Building the largest 3d printer I think ![]() November 13, 2019 07:02AM |
Re: Building the largest 3d printer I think ![]() November 13, 2019 08:14AM |
Re: Building the largest 3d printer I think ![]() December 03, 2019 11:15AM |
Re: Building the largest 3d printer I think ![]() June 19, 2020 05:11AM |
