First FDM Solar Powered 3D printer
September 13, 2011 09:24PM
Reprap mendel Running of Batteries powered but the sun. This Reprap Mendel is Running Ramps 1.3 with SD card add-on allowing it to to print without a computer plugged in. More information about the Electronics can be found @ Ultimachine.com Printing with biodegradable PLA made from Corn using only Sun power.
I know of only one other 3D printer printing with the sun & sand [www.youtube.com] , but not FDM
First FDM solar powered 3D printer
[youtu.be]
Edited 1 time(s). Last edit at 09/14/2011 07:11AM by 2robotguy.
Re: First Solar Powered 3D printer
September 14, 2011 03:57AM
Sorry you're not the first [boingboing.net] it uses the sun to power the electronics through solar panels and it uses a large Fresnel lens to heat the building material (sand).
September 14, 2011 08:43PM
> [boingboing.net]-
> san.html it uses the sun to power the electronics
That printer is not FDM, and he mentioned that printer in his post. RTFM winking smiley
I was wondering if anyone had tried running a RepRap off of batteries and solar power. Pretty cool.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
September 14, 2011 09:07PM
I run one off batteries on occasion, since I use XT60 connectors for power, I already had some batteries that just plugged right in. handy when I was moving things around and didn't have a good path to run a power cord to the wall.
John
September 15, 2011 02:48AM
Hence why he renamed it 3 hours after I said it. And also added the link to the sand one.
2robotguy
Edited 1 time(s). Last edit at 09/14/2011 04:11AM by 2robotguy.
Sublime
My post was at September 14, 2011 12:57AM
And I was not trying to lower the significance of his accomplishment but rather correct a small error. Which he corrected with elegance and poise. Now he does hold claim to a great achievement.thumbs up
September 15, 2011 06:47PM
OK smiling smiley
It is very cool though.
September 15, 2011 07:43PM
The solar panel from Harbor Freight is only rated at 45W while the Mendel needs about 60-72 W of power. Technically, this is battery powered and the battery is being charged by the solar panel. I wonder if the Mendel would actually run if there was no battery in the circuit.
