troubleshooting with TFT28 V1.2 June 18, 2016 11:41AM |
Re: troubleshooting with TFT28 V1.2 June 24, 2016 07:36AM |
Re: troubleshooting with TFT28 V1.2 June 24, 2016 11:38PM |
Where did you find the firmware? The image you show is not from MKS own Github firmware.Quote
jmn47
i have the MKS SBASE V1.2 but the pb not came from the MKS SBASE.
the screen is power supply without the SBASE, with 12V and i set the jumper on the rear of the TFT28 to 12v.
I don't need SBASE to update the firmware of the screen.
this is some exemple when i upgrade the firmware
the updating seems good, and the home screen is good too, it's just the button that is not displayed correctly
Re: troubleshooting with TFT28 V1.2 June 25, 2016 02:57AM |
Re: troubleshooting with TFT28 V1.2 June 25, 2016 03:25AM |
Official Github Makerbase site:Quote
jmn47
yes it came from your own MKS Github, it's the french firmware...
i modify anything
this is with the english firmware V1.1.4
Re: troubleshooting with TFT28 V1.2 June 25, 2016 03:26AM |
Re: troubleshooting with TFT28 V1.2 June 28, 2016 11:20AM |
Re: troubleshooting with TFT28 V1.2 June 29, 2016 12:47AM |
Don't think you can. They have not published any pre-compiled firmware files.Quote
karabas
How to customize the menu? (not only additional 7 icons).
How to change font?
Where I can get IDE to make my custom menu?
Re: troubleshooting with TFT28 V1.2 June 29, 2016 06:29AM |
dintid
karabas
How to change font?
Did you manage to make custom icons? When I create them bmp - .bin files using the small program they have put on github my MKS device just hangs.
Re: troubleshooting with TFT28 V1.2 June 29, 2016 06:49AM |
I just realized it was the size that caused problems here. Wasn't aware of the different limitations.Quote
karabas
dintid
karabas
How to change font?
No problem with selfmade icons. Just draw in photoshop or any PSD editor and convert to bin
I want rearrange all icons but not only last 7.
I want constant temp reading independent of navigating.
I want conditional assigning of my gcode to icons.
Current version is useless for me.
They do not realize if they go opensource everybody will buy MKS TFT display.
Until that even Nextion seems to be more useful.
Re: troubleshooting with TFT28 V1.2 June 29, 2016 07:53AM |
dintid
You know how to assign 2 gcode commands to a single icon in the more section? Like raise hotend 20mm and then extrude 10mm filament? Should each command be seperated, or?
Re: troubleshooting with TFT28 V1.2 June 29, 2016 08:28AM |
karabas
dintid
I think as function in config ( didnot try myself)
# "Function" command line
> Function_btn1_cmd: M84;
> Function_btn2_cmd: G28; G29;
Re: troubleshooting with TFT28 V1.2 June 30, 2016 05:03AM |
No I didnot, thanx. Now I have noticed display control lines in configQuote
dintid
karabas
dintid
Yea, makes sense
You can by the way hide or show those two icons and change their functions if you like (I bet you allready knew that, but just wanted to say it anyway )
Re: troubleshooting with TFT28 V1.2 July 03, 2016 03:42AM |
Re: troubleshooting with TFT28 V1.2 July 11, 2016 12:28PM |
Re: troubleshooting with TFT28 V1.2 July 11, 2016 04:46PM |
Re: troubleshooting with TFT28 V1.2 July 28, 2016 02:19PM |
Re: troubleshooting with TFT28 V1.2 September 03, 2016 12:23PM |
Re: troubleshooting with TFT28 V1.2 September 12, 2016 02:56AM |
Re: troubleshooting with TFT28 V1.2 November 20, 2016 04:39AM |
Re: troubleshooting with TFT28 V1.2 November 20, 2016 05:01AM |
Re: troubleshooting with TFT28 V1.2 November 20, 2016 04:08PM |
majurca
Hi everybody
I am happy that you like the images that I have done.
[github.com]
I also add some commands for bed leveling associated custom buttons.
Re: troubleshooting with TFT28 V1.2 November 27, 2016 05:16PM |
Re: troubleshooting with TFT28 V1.2 November 29, 2016 12:06PM |
Re: troubleshooting with TFT28 V1.2 November 30, 2016 07:50AM |
Re: troubleshooting with TFT28 V1.2 November 30, 2016 05:20PM |
Re: troubleshooting with TFT28 V1.2 January 03, 2017 07:23AM |
Re: troubleshooting with TFT28 V1.2 January 30, 2017 08:41AM |
Re: troubleshooting with TFT28 V1.2 February 07, 2017 01:01PM |
